Drive app fails to send GPX file - again...
Garmin Drive is more and more the same as the Tread app, tracks works fine routes not
Unfortunately, true. The only 100% guaranteed safe transfer choice is wired GPX file copy directly into the Garmin/GPX folder in the device. Preferably on an SD card. It is a little more work, but worth the effort.
Garmin Drive works perfectly for me when it comes to tracks and routes, now that I’ve replaced the latest version, v4.29.25, with the older v4.28.14.
i´m having issues with the Garmin Drive 4.29.33 is not capable to send the dowloaded .GPX from Routerplaner app to the Garmin Zumo XT... i selected all kind of versions and always same topic "Address was not found" ... any one know why? solution?
i have same issue, version 4.29.33 not direction found , not works.
Try opening a second iteration of the Drive app and then get rid of the first. Then the send to device dialog should appear. I reported this issue (looks like a refresh issue to me?) after Garmin broke the Android Version Prior to 4.29.28. I was asked to send further details but didn't. The Garmin bod said it could not possibly happen.......but I sent screen shots.
The older v4.28.14 works
How do you select an older version of the drive app?
Everyone is having problems since the Drive app was updated. On my old SE10 iphone I am still running v4.23.32 without any issues.
Same with the Tread app. There the problems start when your route contains more than 60 routepoints (start and end included).@Guzt I've been through this before. I recently turned off automatic updates in the Google Play Store, so I hope to permanently stay on V4.29.25. Although my first choice might be to use a USB cable and the MRA Connector application.
