  2. Export assistance
  3. [Export] Garmin
  4. Drive app fails to send GPX file - again...
18 Posts 9 Posters 1.7k Views 4 Watching
  • Wallace Shackleton Wallace Shackleton
    I had a bad experience yesterday morning, having sent my route to Drive in the usual way only to have Explore intercept the route and corrupt it.
    This was the last thing that I needed, standing on the driveway, at 5AM, in the dark about to set off to be let down like that.
    Luckily, I knew where I was going, but no waypoints for the destinations was hard enough but my planned fuel stops went right out the window, as a Scot it would have hurt me to play Motorway prices for fuel!
    No doubt, I will now be forced to learn Explore, which seems so counter intuitive to use... I miss Basecamp.
    I've just discovered another thread in this Forum and going back to the previous version of Drive. I'll give that a try.
    The thought struck me that Garmin are "shooting themselves in the foot" by implementing improvements that make things worse. Ultimately making the decision easier to buy a tablet device and ditch the Zumo XT entirely.
    Don Stauffer
    Don Stauffer
    Don Stauffer
    @Wallace-Shackleton Was this a problem with Explore and Drive on an Android device? I removed Explore from my phone some time ago due to problems like this.
    • Don Stauffer Don Stauffer
      @Don-Stauffer no, this was due to a bad Drive App update for only Android a few days ago.
      MRA Lifetime Gold
      • Thomas Schäfer
        Thomas Schäfer
        Thomas Schäfer
        It appears that the latest update to Garmin Drive has re-established the connection to the Explore app without asking, bringing with it all the known issues.
        A possible solution is to install an earlier version of Drive and disconnect the Zumo from the Explore app.
        A detailed description (in German only) can be found here.
        https://www.naviboard.de/thread/68606-wie-werde-ich-eine-bestehende-verbindung-zu-garmin-explore-wieder-los-sorry-lang/?postID=561581#post561581
        This worked perfectly for me and I can now send routes and tracks again.
        Freundliche Grüße/Kind regards/Met vriendelijke groeten
        Thomas
        • Kobutex Motorreizen
          Kobutex Motorreizen
          Kobutex Motorreizen
          If you use the connector to transfer your routes to the Zumo, the routes are transferred correctly. Garmin is really moving towards using tracks; however, you can still add your waypoints to the track within Explore.garmin.
          Currently, the connector only works on a Windows PC; hopefully, it will work on Apple PCs again with the new website.
          Thomas Schäfer 1 Reply Last reply
          • Kobutex Motorreizen Kobutex Motorreizen
            Thomas Schäfer
            Thomas Schäfer
            Thomas Schäfer
            @Kobutex-Motorreizen I think the discussion about the MRA – Garmin Drive – Garmin Zumo issue is more relevant when you’re out and about, and less so when you’re sitting at your computer at home. In that case, the connector is, of course, an alternative.
            Thomas
            • HABVEN aka MrMRA
              Garmin Drive is more and more the same as the Tread app, tracks works fine routes not
                Unfortunately, true. The only 100% guaranteed safe transfer choice is wired GPX file copy directly into the Garmin/GPX folder in the device. Preferably on an SD card. It is a little more work, but worth the effort.
                • Thomas Schäfer
                  Thomas Schäfer
                  Thomas Schäfer
                  Garmin Drive works perfectly for me when it comes to tracks and routes, now that I’ve replaced the latest version, v4.29.25, with the older v4.28.14.
                  Thomas
                  • Oscar Perez Lopez
                    Oscar Perez Lopez
                    Oscar Perez Lopez
                    wrote last edited by
                    i´m having issues with the Garmin Drive 4.29.33 is not capable to send the dowloaded .GPX from Routerplaner app to the Garmin Zumo XT... i selected all kind of versions and always same topic "Address was not found" ... any one know why? solution?
                    • Oscar Perez Lopez
                      Oscar Perez Lopez
                      Oscar Perez Lopez
                      i have same issue, version 4.29.33 not direction found , not works.
                      • Mzokk
                        wrote last edited by Mzokk
                        #17
                        Try opening a second iteration of the Drive app and then get rid of the first. Then the send to device dialog should appear. I reported this issue (looks like a refresh issue to me?) after Garmin broke the Android Version Prior to 4.29.28. I was asked to send further details but didn't. The Garmin bod said it could not possibly happen.......but I sent screen shots.
                        • Thomas Schäfer
                          Thomas Schäfer
                          Thomas Schäfer
                          The older v4.28.14 works
                          Thomas
                          Thomas Schäfer
                          Thomas Schäfer
                          Oscar Perez Lopez
                          Oscar Perez Lopez
                          Don Stauffer
                          Don Stauffer
                          Kobutex Motorreizen
                          Kobutex Motorreizen
                          Wallace Shackleton
                          Wallace Shackleton
                            95
                          • Route exporteren uit beta
                            Rob Veerman
                            Rob Veerman
                            68
                            BMcG
                            BMcG
                          • Startpunt wijzigen
                          • V6 - Track Navigation
                            Thomas Schäfer
                            Thomas Schäfer
                            1.7k
