problem exporting from iphone to zumo xt using garmin drive?
HI , i have a problem , i plan routes on my laptop using MRA then use the MRA app on my iphone to send to my Garmin zumo xt in the following order
- open MRA app on phone
2)open routes - click download
- choose GPX1.0 as the download format
- click export
6)click on garmin drive app
this used to work but now when i click on the garmin drive app to export it to i get " NO ADDRESS FOUND" .I have spoken to garmin uk support and they say the fault is with MRA not garmin?
can any one help with this as it appears to be a very common problem from what i have read on the internet
- click export
@Andy-taylor-0 It’s been widely reported that the last update that the Garmin Drive app received a few days ago is the problem. It’s being discussed in this topic. You’ll need to translate unless you can read Dutch:
You're not alone, actually one of many. It's an issue that is reported to Garmin by iPhone users in combination with a Garmin Zumo XT. Garmin is aware of the problem and is working on it. You could use the Connector app and connect your device with an usb cable to your computer.
This isn't the first time that Garmin has broken the Drive app, resulting in connection problems to the XT. And it likely won't be the last...
Using the wired USB cable from your computer to the XT is the best alternative. In my view, it's the best option of all. Doing a GPX file copy is simple, and if you do it manually, you can copy directly to an SD Card inserted in your XT. It's beyond the scope of this topic, but an SD Card has advantages vs. internal storage.
Moving on to the XT2/XT3, Garmin is making it more unreliable to copy routes via their app. The Tread app is used for the XT2/XT3, and using the app for transfer can cause problems for route re-calculation. If you want to continue with Garmin's beyond the original XT, it's a good idea to get used to wired transfers now.
@John-S-Parry Using the cable and the laptop is a fine alternative when being under the right conditions, but the problem is that I can't easily wirelessly transfer another gpx file to my Zumo XT when sitting somewhere down the road on a terrace e.g. Garmin will (have to) fix it (eventually).
Understood. There is nothing more convenient than performing an app transfer. It's one of the things that's really appealing about using the MRA app for navigation.
And yes, Garmin will fix the Drive app transfer issue. They always do, but more on their timeline instead of yours. Looking forward, I was referencing life with the XT2/XT3. The XT is 6-years and 2-generations old, and existing units won't last forever. Garmin has since significantly integrated their cloud based Explore DB into the XT2/XT3 architecture. When using the replacement Tread app for route transfer, your route components are stored in the Explore DB for future recalculations. The bottom line is that it doesn't always work well. Routes sometimes get recalculated incorrectly, or sometimes not at all. The only way to guarantee your routes remain intact is to not enable the Explore DB, which means you have to perform a wired transfer.
Garmin might fix this behavior in the future, but based on their history, it's doubtful. They're moving towards a world where they want everything performed within their Tread/Explore universe, including initial route creation. I don't think optimally bringing in external GPX files is high in their priorities.
