  4. I’ve just tried V6. A few suggestions.
14 Posts 10 Posters 517 Views 6 Watching
  • Giancarlo e
    Giancarlo e
    Giancarlo e
    wrote last edited by
    I have just tried V6, and I must say that an excellent job has been done with this new version; it represents a significant leap in quality. I have nothing but praise for the developer(s). That said, I would like to offer a few suggestions. I own a TomTom Rider 550, and I recently purchased a Carpuride 702 Plus—which runs on Android 14—on which I have installed the MyRoute-app (I do not use Android Auto). I have included an image of my setup to illustrate my suggestions. I must acknowledge that TomTom has managed to fit all the necessary information onto a 5-inch screen, and one of its greatest strengths is the side progress bar, which I find very useful. I believe there is ample room in the white space at the bottom left to place such a progress bar; that area currently feels underutilized. In any case, it could be implemented just as TomTom does—by making the progress bar optional. If you look closely, TomTom’s bar also displays upcoming gas stations along the route. This approach could be adopted, potentially replacing the black box that currently shows the distance to the next gas station, thereby freeing up more space for the map. The Carpuride 702 is sufficiently large (7 inches), and it works well for me as it is; I would simply add the progress bar in that space, where it would fit perfectly. Additionally, the blue box in the top-left corner seems excessively large and could be reduced. I offer these suggestions primarily with smaller devices in mind.
    Daniel 7 1 Reply Last reply
      I cannot agree more. I also think a TomTom like info bar cleans up the interface and at the same time to be able to put more info on your screen without the change it is overcrowded with info.
      • Jeroen ekkel c
        Jeroen ekkel c
        Jeroen ekkel c
        Ook mee eens heb ook de Carpuride W702 Pus het neemt te veel ruimte in beslag in het linker gedeelte, de venstertegels zijn te groot voor een 7 inch scherm, betreft de optie zoals de TomTom lijkt mij ook beter ziet er wat geordnerd uit en kriskras verdeeld over het scherm me grote en klein tegels.
        De W70s plus werkt goed na een eerste rit maar nog niet goed kunnen testen in de praktijk aangezien ik de Carpuride nog niet zo lang heb, en het seizoen wel voorbij is en het voorjaar maar eens grondig testen in de praktijk met goed weer. de app installeren en gebruik zonder telefoon is al een verbetering en de online verbinding via Hotspot in de praktijk zal ik moeten testen hoe het gaat met gpx bestand route inplaats van track, dat moet ik nog uitvogelen.
        • Giancarlo e
          Giancarlo e
          Giancarlo e
          La prueba de hoy fue para probar la V6 y muy bien. Ya habia realizado varias pruebas con y sin conexión de internet mediante punto de acceso desde el móvil. Con una pantalla de 7" con la del Carpuride 702 plus, la verdad es que aunque los cuadros de indicaciones sean grandes, el mapa se sigue viendo bien. Sin embargo creo que tomando las buenas ideas de otros (barra de progreso de TomTom, la interface se puede mejorar aun mas y dar mas espacio a los mapas. Esto beneficiaria mucho mas a personas que usan dispositivos de 6" e incluso de 5". La barra de TomTom da mucha informacion. Está muy bien estructurada. Yo creo que si se agrega esta opción a la interfase de la V6, se estaria dando un paso mas. Ademas se podria hacer que se active o desactive según el gusto de cada quien
          • Giancarlo e Giancarlo e
            Daniel 7
            Daniel 7
            Daniel 7
            Hello,
            I’m curious whether the next turn instruction—specifically the text below the arrow—is displayed in a larger font in the new Android app. In the previous version, the font size in that area was simply too small for a mobile phone, making it difficult to read while riding a motorcycle in bright sunlight. During a 1,000 km trip, I found that even my TomTom Rider 400 offered better visibility regarding the distance to the next turn. I would really appreciate a larger font size for this information. It seems to be well-implemented on your Carpuride unit. I agree with you that the info bar on the TomTom is well-designed.
            See here:
            https://forum.myrouteapp.com/topic/11044/font-for-the-distance-to-the-next-turn-to-smal
            BMcG 1 Reply Last reply
            • Giancarlo e
              Giancarlo e
              Giancarlo e
              En la Carpuride 702 plus, todo se ve perfectamente, incluso diría que demasiado grande. No tengo ninguna queja de como se ve. Pero si creo que se puede optimizar de manera de que quede mas espacio para el mapa. Yo creo que con una barra de progreso bien planificada se puede quitar cosas de la pantalla (por ejemplo la de la gasolinera proxima). Entiendo que complacer a todos es imposible Cada uno tiene unas necesidades y gustos diferentes. Pero la barra de progreso puede ser opcional como en TomTom. Incluso en TomTom se puede establecer el tamaño. Hay 2 tamaños. Y tb está la opción de quitarla. La Barra de progreso en muy util y bien diseñada, seguro sería un gran aporte a esta excelente aplicacion.
              • Jacob Waterweg
                Jacob Waterweg
                Jacob Waterweg
                I also love the TomTom progress bar. I use its wide version, which offers even more info: distance to the next gas station and the time loss at the next delay on the route.
                Motor 1: MRA op Ulefone Rugking Pad Pro met Android 16
                Motor 2: MRA routes op TomTom Rider 550
                Auto: MRA op Android Auto vanaf Motorola Edge 50 Fusion met Android 16
                • Giancarlo e
                  Giancarlo e
                  Giancarlo e
                  La verdad es que nunca he probado la barra ancha. Ya me parece mas que suficiente la angosta, pero voy a probarla a ver que tal. Esta posibilidad de tener o no tener una barra de progreso, mas ancha o mas delgada es lo que sugiero a los desarrolladores de MRA incluyan.
                  • Olivier Weinand
                    Olivier Weinand
                    Olivier Weinand
                    I also miss a progression bar as used in the TomTom Rider and even in the Garmin XT (in that case for approaching traffic jam or road worksy The distance to the next Gas station is in deed very convenient.
                    • Daniel 7 Daniel 7
                      Hello,
                      See here:
                      BMcG
                      BMcG
                      BMcG
                      @Daniel-7 the new V6 does display the distances in a larger format for both the next & 2nd next turns
                      the distances are now to the side of the direction arrows instead of below
                      • Stanisław
                        Stanisław
                        Stanisław
                        As we already have a progress bar at the bottom that can easily be shown if needed, I suggested placing some information there, such as the two nearest petrol stations. This information could be useful. I also miss the old TT bar. 🙂
                        Staszek
                          Thanks for all the feedback!
                          Already working on improvements for the next update 🙂
                          • Herman Veldhuizen
                            whateve we add , I hope the user can select wether its shown or not (like we can for some already).
                            For my use cases I am e.g. not interested in the fuel stations or progress bar.
                            But what I do miss is to have the name of the next point visible all the time (and not only just before arriving there). I know my points by name (and not by number) and I would like to know where I am driving to...
                            • Giancarlo e
                              Giancarlo e
                              Giancarlo e
                              #14
                              Si, lo ideal es que cada usuario pueda activar o desactivar lo que desea. Y sobre lo del nombre visible del próximo punto, me parece una excelente idea.. tb esto podria ser activable o no ..
                              Giancarlo e
                              Giancarlo e
                              Jacob Waterweg
                              Jacob Waterweg
                              Stanisław
                              Stanisław
                              Jeroen ekkel c
                              Jeroen ekkel c
                              BMcG
                              BMcG
                              Olivier Weinand
                              Olivier Weinand
                              Daniel 7
                              Daniel 7
                                150
                                Ruud Bijkerk
                                Ruud Bijkerk
                              • Route exporteren uit beta
                                Johan 5q
                                Johan 5q
                                125
                              • Website update - Trip book PDF, route lock for collaborators, a close button in the planner and more
                              • Startpunt wijzigen
                              • 'Geen adres bekend'
                                Rob Veerman
                                Rob Veerman
