Auto skipping in next version (6)
well i will wait and see. one day it will be fixed i hope. I am clearly not the only one asking for route priority over point priority. The current behaviour is a hybrid between point and route priority. As long as you follow the route exactly as planned then all is good. but if you deviate from the route you dont know if you should follow the instructions from the app or not. It would be good if the app had a setting where you can say whether you want point priority or route priority (or a hybrid like today but when it is easy to skip both forwards and backwards then the hybrid version is probably not needed anymore).
many new features coming apparently. All good but resources are not unlimited and my concern is that these new features will consume the time needed to fix issues in the core. I like MRA very much and I just need to be a bit more patient i guess.
@Herman-Veldhuizen this comment is about what version?
I am not a alfa or beta tester. i am using the latest version on google play (5.2.2).
Clear! This has been completely redesigned and I am positive you will enjoy it better
@Corjan-Meijerink Sounds very good. thanks for the good work.
I'm a Beta tester and I can confirm that I'm very positiv about the new auto skipping!
But for it's still Beta I can not say much more. You will see. -
Now that v6 is available to everyone, I'm still curious to learn how the new logic for automatic waypoint skipping actually works.
Understanding avoids irrelevant questions.
Thanks in advance. -
me too.
i did some testing today and noticed the following:-i dont get notified anylonger when I have reached a shaping point (the setting for waypoint notification is "All"). I only get notified that a waypoint is coming.
-the app recalculates a route sometines even when the setting for automatic recalculation is off. That happened also in previous versions but that seems to have a side effect. see my next observation.
-when you deliberately don't visit a shaping point then the app skips the point more often then before. Wether it skips a point seems to depend on whether the recalculate kicks in or not. If you rejoin the route before the recalculate kicks in the missed point is skipped. if the recalculate kicks in before you rejoin the route the missed point is not skipped.
some more info to my first note. The waypoint notification (the audio message "Reached waypoint N") appears to have been replaced by a beep and a visual message ("Waypoint N passed"). See screenshot below. This is OK with me but it only shows up sometimes, most often it doesn't. Why i dont know of coarse, could it be that the app gets confused when a point has been skipped? The other thing is that this visual message, when it shows up, it often shows up a little bit too early, which can be seen in the same screenshot below.
Another note:
-In previous versions the app would inform me when a waypoint has been skipped, those messages I haven't seen in V6. The app stays silent when it jumps to the next point on route.
I have also noticed that waypoints are not being skipped correctly. I have created a ticket, shared a video of the issue, and provided the log file.
