ETA icon not displayed in Android Auto
Today I drove for the first time with the new app version 6.0.0. (532). What I observed is that the icon for the ETA information is missing. I only see a cross (see screenshot). I have tried with all possible values (way-point, via-point and finish). In all situations it's the same. When I look on the phone I do see the correct icon (finish flag). Is this is error?
Sorry, don't drive with Android Auto often.
What happens if you press the icon?
I can confirm that it's not designed to show any MRA info so this is probably something default from your Android Auto.
What version Android / Android Auto are you using? -
As far as I know the navigation stops, but I'm not sure. The version of AA I use is 17.9.664044. In the previous version I didn't see this cross, but the normal icon (e.g. finish flag).
Good! Then this is simply the exit button of Android Auto
Nothing from us. All as expected then.
I'll research if we can do anything with this "button" but no priority now. -
Then why didn't this occur in the previous app version (5.2.2)?
I'll research if we can do anything with this "button" but no priority now.@Corjan-Meijerink of you push that button the route will be ended. The ETA is shown 15.26
@Léon-Hassing We've updated some internal supported versions
I never drive with Android Auto and in the devices I tested this never appeared.
It's a combination between the device / Android version / Android Auto version.Nobody from Alpha / Beta reported this so you are the first to discover
As said, I'll check if we can do something with it.
But having an exit button there is not that bad by itself. -
But having an exit button there is not that bad by itself.@Corjan-Meijerink I will check it tonight on a short ride
But having an exit button there is not that bad by itself.@Corjan-Meijerink what I already suspected. In the left corner is the ETA visible
The X in that button ends the route!
Looks good
I would also much rather see the corresponding icon instead of an "X."
If we want all vehicles to have CarPlay/Android Auto, we need to work together to create a really attractive navigation system.
P.S. Over the weekend, I’ll run some tests with my Chigee, and I’ll let you know if I come across anything else.
