Problem with HERE, getting the route correct ??
below a link to a route.
Trying to get a old route into MRA.
I try to get the route around point 24 going down, but HERE refuses to do so, TT and OSM route the way I planned.( going down and up again.)
https://www.myrouteapp.com/nl/social/route/14639730?mode=shareanybody got an idea why?
@BertM the data for the Here map is different on the loop to the north of Marienhagen
the Here map says it is not possible to pass
this appears to be because the Here map has a small section of this road marked as "Local Access Only"
maybe the road priority has changed & Here is correct & OSM & TomTom are wrong
the sure way to know is to physically investigate -
the sure way to know is to physically investigate@brian-mcg What card did you use to find this ?
It was 10 Years ago I did that trip... maybe we do it again and check
Thank you for the help, got me busy for some time..
@BertM the first picture is MRA just using the 3 different routing calculators, Here, TomTom & OSM
by moving the 2 points closer together I was able to isolate / narrow down where the Here card was failing
then looking on the Here Map Creator site I was able to find the local access restrictionthe reason that the route is working for you in one direction & not the other is you were lucky / unlucky that you have placed point 33 exactly on the restricted road so the routing passes through
if you move point 22 so it is next to point 33 then the route will pass both ways
