  4. Routenplaner on iPad
11 Posts 6 Posters 1.2k Views 5 Watching
  • Jörgen
    Hi, the Routenplaner on iPad is very difficult to use. Moving the map and zooming the map is nearly not possible. Zooming only with the plus/minus Button. I tried with Safari and Chrome Browser and there is no difference. The map moves a little bit (sometimes) and then the complete screen moves, but not the map.
    Google maps works as expected.
    Any one with the same problem?
    JP d 1 Reply Last reply
    • Hubert Thoring
      Hey @jörgen,
      With me everything works without problems, planning as usual, zooming in or out with two finders, etc. Maybe you should restart, so turn off the iPad longer.
      Mine is an iPad 9. Gen. with iOS 26.6.2 which I now drive to 26.7 update.
      VG 👋
      iPad 9. G iOS 27.2.0/iPhone 16e iOS 27.2.0/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
      • Hubert Thoring
        Even with iOS 26.7 everything is okay on my iPad, VG
        • Lluis Arasanz
          I noted this behavior when using satellite layers. If I change to Michelin layer this issue disappears. But always appears with satellite layers
          • BMW F750GS
          • Jörgen
            @lluis-arasanz very good hint, it is really dependent what map layer is in used.
            Why is that, a question to the developer.
            • Jörgen Jörgen
              JP d
              JP d
              JP d
              @Jörgen yes, same here. I go to layer and chose HERE move the map then go back to layer and chose Google maps. But if I select satellite it freezes.
              Or like you said the screen moves not the map. I have an Amazon fire tablet and don't get that issue so guessing it's an iPad issue. 🍻
              • Risto Motorcycling
                Risto Motorcycling
                Risto Motorcycling
                wrote last edited by
                Already many months i have had same problem, all different maps freezing or whole screen is moving. Problem started slowly but now comes every single time when i try to create new route. Some times i have managed to create new route using Michelin map.
                MRA settings are to use HERE map.
                I have iPad pro 3rd gen and problem exists with several IOS up to present 27.0.1
                At bonus most of 1.1 transfers to XT from my iPhone 16 ProMax 27.0.1 fails connection to Garmin app
                  Risto Motorcycling
                  Risto Motorcycling
                  In addition to below message, same exists also in my iPhone 16 Pro Max
                  And my Garmin is updated+ Garmin Drive 4.29.29
                  • Aiello antonino
                    I have the same problem too: if you select the Google map, everything freezes... things improve when switching to Michelin or OSM... sometimes, when scrolling across the map on the display, the zoom activates instead of the map moving...
                    Risto Motorcycling 1 Reply Last reply
                      Risto Motorcycling
                      Risto Motorcycling
                      Risto Motorcycling
                      @Aiello-antonino same here, zoom activates instead of map moving, its very annoying
                      • Aiello antonino
                        Out of curiosity, I tried opening the planner from the NEXT app, and it seems there are no issues there... give it a try yourselves and let us know how it works for you...
                        JP d
                        JP d
                        Risto Motorcycling
                        Risto Motorcycling
                        • Map lock
                          tfdahazellgmail.com
                          tfdahazellgmail.com
                          81
                          117
                        • Route exporteren uit beta
                          Rob Veerman
                          Rob Veerman
                          85
                          Guzt
                          Guzt
                          2.1k
                        • Beta abonnement
                          Jeroen ekkel c
                          Jeroen ekkel c
                          376
                        • V6 - Track Navigation
                          BMcG
                          BMcG
                          Guzt
                          Guzt
                          1.7k
