  2. MRA Routeplanner Next Beta
  4. Animation
13 Posts 4 Posters 32 Views 4 Watching
  • LennyO
    wrote last edited by
    Am I doing something wrong?
    During the animation the map is spinning, jerking, acting up. Call me dizzy... 🙂
    • LennyO LennyO
      @LennyO Yes, that’s correct. I tried a test route in my hometown. On a route with lots of bends, the animation is indeed a bit “restless.” But on a somewhat longer route through mountainous terrain, the animation is absolutely awesome!
      Because of the tilt of the map, you now also get a 3D view. An amazing feature!
      Maybe Corjan could add a setting to play the animation a little slower. At the moment, you start at 1 and can speed it up to 2 and 4. Perhaps we could also go in the other direction with -1 and -2...
      • Jörgen
        The rotation should be a bit slower. For example, when travelling south, it should only rotate when there is a significant change in direction. Otherwise, the map should remain stationary.
          I've added a north up mode
            @Corjan-Meijerink If you select the “North up” option, you still get a message during the animation telling you that you can use the right mouse button (or your fingers on a tablet) to adjust the tilt and rotation of the screen. However, this obviously does nothing when “North up” is selected.
            • Jörgen
              Looks much better. 👍
              For me the first button does not change anything.
              • Jörgen Jörgen
                @Jörgen It probably does, turns off waypoint highlights in the animation.
                Hover to see the hint
                  @Rob-Verhoeff Fixed
                  • LennyO
                    wrote last edited by LennyO
                    I noticed that the animation dot does not move with even speed... not sure if it is my comp or the server or what... Also we lost the choice of zoom.
                    On a long route x4 is not enough in my opinion... what does x4 equal to in the current version? Looks like "Fast", no?
                      Correct, but scaling is based on route distance.
                      So it's not the same per route / tracklog.
                      LennyO 1 Reply Last reply
                        @Corjan-Meijerink Thank you, Corjan!
                        What about the uneven speed?
                          Focus on what "seems" to be nice 🙂
                            @Corjan-Meijerink Sorry... not sure what you mean by that.... Not to pay attention to the uneven speed? I just want to understand the root cause, is it "me" or "you" or the link in between....
                            • A21 Tracklog colors say something?
                            • Reizen delen met NIET MRA gebruikers
                              Albert van den Elsen
                            • Verminkte route op TomTom.
                              Jacob Waterweg
                              Jacob Waterweg
                            • Navigatie via android auto wil niet over de veerpont
                            • Probably a me thing
                              Solo1138
                              Solo1138
                            • F018 Deleting photo from moment is not possible
