  2. Export assistance
  3. [Export] Garmin
  4. transfer from phone to zoom xt
31 Posts 13 Posters 5.6k Views 3 Watching
  • mark hooton
    mark hooton
    mark hooton
    Im having trouble try to send a route from my samsung phone to my Garmin zoom xt nav.
    I save the route as 1.0 then when prompted to export I export it then it comes up with a share tab, it did not have this option a week ago, when I press the share tab it open Garmin drive to a different screen I have not seen before.
    • mark hooton mark hooton
      @mark-hooton read it on my website, yeah it is in dutch but there is a translation button https://routes.lexwill.cyou/gps-routes-maken/#Garmin-Drive-app
      MRA Lifetime Gold
      • Mzokk
        Garmin have broken the Drive app for Android phone users. Register your complaint to get them to fix it. Some people have side loaded older versions of the app and turned automatic updates off. I don't think I should access an old version from a potentially iffy site. Garmin should fix it asap.
        • Mzokk
          The broken version is 4.29.25 and was released on the 3rd of September.
          • Kobutex Motorreizen
            Kobutex Motorreizen
            Kobutex Motorreizen
            If you use the connector to transfer your routes to the Zumo, the routes are transferred correctly. Garmin is really moving towards using tracks; however, you can still add your waypoints to the track within Explore.garmin.
            Currently, the connector only works on a Windows PC; hopefully, it will work on Apple PCs again with the new website.
            Mike wiruth 1 Reply Last reply
            • Arno van Lochem - Senior RX
              You really shouldn't use version 1.0; that is for Zumos from the last century. (like the Zumo 220)
              For the current generation of XTs (XT/XT2/XT3), it is best to use GPX version 1.1 or 1.2, although it should be noted that 1.2 is an MRA version.
              • mark hooton
                mark hooton
                mark hooton
                thanks for you help I have bought a carpuride for the time being as I off to the picos October.
                  @mark-hooton I would spend as much time as possible learning the nuances between the navigation app and Carpuride and your Garmin. Better to discover on familiar ground than whilst touring.
                  • Mzokk
                    Just got this reply back from Garmin regarding the borked drive app. After I called them I uploaded an email with a pictorial description of the issues the the current version of the Drive app had caused. I think that a fair few people had contacted them about the issue which was good, as it will hopefully be resolved soon.
                    Thank you for your email.
                    This issue will be resolved in an upcoming Drive app update. We'll notify you via email once the new version is available for download in Google Play.
                    Apologies for any inconvenience caused.
                    Kind regards,
                    Jake
                    Garmin Europe
                    • Travellexxie
                      I have received more or less the same answers from the German and Dutch Garmin CS
                      MRA Lifetime Gold
                      • Mzokk
                        From last night a new version of the app is available. 4.29.28
                        Having used the app for me there appears to still be a bit of an issue with a refresh of the app before it functions to transfer a file. I initially could not get the app to function but found that opening a second instance of the app then closing it initiated the send function. Previously the app opened and the send file function was initiated after a request to share a file was initiated. I have subsequently found that minimising the app then opening it again also causes the app to work. I have no Idea if this is associated with a setting on my phone or its a bug in the new iteration. I sent this reply to Garmin last night when I finally got the app to transfer routes. I haven't received a reply yet.
                        Further to my last e-mail. I can get the app to work but to get the app to recognise the file to be transferred I have to share the file with the drive app.....nothing happens. If I the open a second instance of the drive app then close it the file dialog appears in the first instance of the Drive app and it transfers to the ZumoXT.
                        Hope this helps?
                        • Travellexxie
                          I had to restart the app and now everything is working fine, tablet and phone.
                          MRA Lifetime Gold
                          • J2FK
                            J2FK
                            J2FK
                            Ik was reeds terug gegaan naar een vorige versie en ga die denk ik nog wat houden, tenzij er een meerwaarde is aan de nieuwe versie. Wat mag die dan eventueel zijn?
                            • Kobutex Motorreizen Kobutex Motorreizen
                              Mike wiruth
                              Mike wiruth
                              Mike wiruth
                              @Kobutex-Motorreizen Can you explain how I can get my routes to my Zumo XT using a cable? I'm leaving this Saturday and have all my routes on my phone, but like to have them on the garmin too. Especially if it's raining. How do I do it?
                              Thanks very much for your help.
                              Mike
                              Mike W
                              2013 Honda Goldwing
                              Bushtec Trailer
                              Garmin Zumo XT
                              Nebraska
                              • Mike wiruth Mike wiruth
                                Mike
                                @Mike-wiruth Connect your Garmin to your computer.
                                Drag or copy the GPX file to the GPX folder on your Garmin.
                                zūmo XT Owner's Manual - Transferring GPX Files From Your Computer https://share.google/JWKFXr2WbfmiWbmmT
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Motorola Edge 40 "offline"
                                Sena SLR 3
                                Sena 50 R
                                • AWDC LAO
                                  On a Mc use an SD-card, not a cable.
                                    @Peter-Zehentreiter in my opinion unnecessary complicated. Just connect the XT to your computer. Wait until the device and sd are recognised then use the connector in MRA to export the route using the 1.2 format. Works like a charm
                                    Peter Zehentreiter Travellexxie Mike wiruth 3 Replies Last reply
                                      @Marinus-van-Deudekom Well, that's not exactly complicated...
                                      I'm simply describing the standard method for transferring GPX files to a Garmin device.
                                      I realize there are different ways to do it, and I know how they work.
                                      BMW R 1250 GS
                                      DMD-NOR7E 7"
                                      SPC Universal mount
                                      Sena SLR 3
                                      Sena 50 R
                                        wrote on last edited by Travellexxie
                                        #19
                                        @Marinus-van-Deudekom MRA connector and XT with sd-card. I wish you lots of succes, most of the time it will not succeed with a sd-card.
                                        Save the route(s) and drag them, in case of more routes, to the XT itself (I use good old Total Commander for it), de SD is in my case only for music. In case of emergency (XT has to set back to factory settings or hard reset) you can put them on your XT with your phone and the Drive app.
                                        I agree with the 1.2
                                        MRA Lifetime Gold
                                        • Travellexxie Travellexxie
                                          @Travellexxie What I meant was if you want to tranfer using the cable connection wait for Windows to recognise both the XT and the SD card. Don't trafer the export to a SD card. You're completly wright about that.
                                          Travellexxie John S Parry 2 Replies Last reply
                                          Don Stauffer
                                          Don Stauffer
                                          Kobutex Motorreizen
                                          Kobutex Motorreizen
                                          Mike wiruth
                                          Mike wiruth
                                          J2FK
                                          J2FK
                                          mark hooton
                                          mark hooton
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • MRA AI Routeplanner - Improvement
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                          • Ability to hide all waypoints at once after planning?
                                          • File types for download route
