  2. Export assistance
  3. [Export] Garmin
gpx 1.1gpx 1.2garmin xt
196 Posts 22 Posters 64.0k Views 5 Watching
  • Mzokk
    Tracks can be set at various widths on the Garmin Unit for the XT at least (the XT2/3 might be similar) the maximum track width is too thin to be seen beneath the route unless the route diverges. To change the displayed track width you need to edit a Theme file. These files are stored on the XT and can be accessed and changed here on the unit. I created a theme called Widetrack which means that the track is always wider than the magenta route line and easily seen. By default this is not the case.
    There are several themes available on the unit and the default for UK units is unsurprisingly United Kingdom.
    To change the Default width of the track I copied the United Kingdom theme on the unit these are .kmtf files and can be read and edited by a text editor such as Notepad.
    They are accessed by connecting your unit to a computer.
    This is a list of the themes onthe UK units and there might be a layout you like more than the one you are using. I copied the uk theme and changed the name to Widetrack.kmtf.
    to Edit the >kmtf files open in notepad
    And scroll down to the track width parameter in the text file. The default for the parameter of track width is "1.00" by default I changed this by trial and error to "2.50" you can fiddle with this yourself to devise a width that suits.
    For comparison this is the same parameter in the original file. You can mess with all of the parameters and as long as its with a named file of your own making you can't break anything.
    Don't forget to change the name of the theme at the top of the file in the text editor so that you can select it in the menu on the unit and it does not overwrite the theme file you altered.
    With the wider track in the theme you can have it look like this during navigation.
    I usually select yellow but you can pick whatever track colour you prefer.
    Guzzist 1 Reply Last reply
    • Carl Lee
      Carl Lee
      Carl Lee
      I'd like to add something about recalculation. I haven't played with 'Up Ahead' places by inserting them into my route but on a normal deviation from a 1.2 route with recalculation left on, I've found there is a recalculation but it logically puts you back on your intended route - maybe with a u-turn or merging with it a little further along.
      @simon-james-hancock, which Zumo do you have? On the XT2, you can change the colour in Tread or the Zumo but the width is done on the Zumo. And if you are using Tread, the track must be put in a collection that is visible. I've found red on the widest to be very visible on the XT2. If you don't see the track underneath when zoomed in, just zoom out a little and you'll see it. I wouldn't want it any wider as otherwise it would obscure junctions etc.
      Steve Jarrell John S Parry 2 Replies Last reply
      • Simon James Hancock
        Simon James Hancock
        Simon James Hancock
        I am trying to avoid using tread. I do al my planning in MRA and save to the garmin sd card.
        • Simon James Hancock Simon James Hancock
          Great thread and great work by all.
          What colour do you use to show your track and thickness? I have difficulty seeing mine.
          Steve Jarrell
          Steve Jarrell
          Steve Jarrell
          @Simon-James-Hancock On my XT3 I use black and set it to the widest width and I can see it just fine. I had forgotten all about the Theme file that @mzokk detailed but I had to create one for my XT in order to see my track as well
          Steve Jarrell
          Western North Carolina US
          2025 BMW R1300GS
          2025 Can-Am Spyder
          DMD T865-X 8" Tablet
          Garmin XT3
          • Carl Lee Carl Lee
            Steve Jarrell
            Steve Jarrell
            Steve Jarrell
            @Carl-Lee said:
            "And if you are using Tread, the track must be put in a collection that is visible."
            Note that it doesn't matter if you're using the Tread app or not. I normally don't use Tread. I place my .gpx files in the /gpx folder using a USB connection.
            When the Garmin XT3 imports them it asks me which collection to put them in. If the visibility of that collection isn't turned I will see the route when you select it, but I won't see the track.
            Steve Jarrell
            2025 BMW R1300GS
            2025 Can-Am Spyder
            Garmin XT3
              Steve Jarrell
              Steve Jarrell
              Steve Jarrell
              #100
              @Simon-James-Hancock I don't like using Tread either. I use a USB C to C cable directly from my Macbook Pro to my XT3 and use the free OpenMTP app to manually place my .gpx files in the /gpx folder. It's VERY fast and works 100% of the time.
              If I do have the Tread app connected to my XT3, Tread (and the Explore website) will automatically synch with collections, routes and tracks that I manually put on the Garmin.
              (Geek overload section follows) 🙂
              Here's a screenshot of what the OpenMTP app looks like on my Macbook (this would look basically the same if I was using File Explorer on a PC) when I've copied my .gpx files into the \gpx folder before the XT3 has imported them into its internal memory.
              The interesting thing that I've discovered is once the XT3 imports the .gpx files, it deletes the Track section from the file but leaves the route information (which in the 1.2 format contains a copy of the track) in the file and does not delete the file. The result of this is that even if you delete the route in the Garmin's internal memory a copy of it is still in the \gpx folder, and it can be imported again and again.
              If you've manually uploaded a gpx file into the \gpx folder it's up to you to delete it manually which is fine with me. Tread skips the \gpx folder and loads the gpx information directly into the devices internal memory.
              Steve Jarrell
              2025 BMW R1300GS
              2025 Can-Am Spyder
              Garmin XT3
              • Steve Jarrell Steve Jarrell
                @John-S-Parry I figured that the recalculation was going to happen and screw up the route. I agree completely with your conclusions including that restarting the route and selecting the closest point as the starting point would have probably put you back on your intended route.
                The Garmin has a LOT of gps coordinates in the track that's embedded in the route section of the 1.2 gpx file so it should be able to take you to the closest coordinate to where you are without recalculating the route.
                If you test it let us know, and I'll do the same. Thanks a lot for the update!
                @Steve-Jarrell I got out again today to run another test of "Up Ahead", but this time without adding/inserting a via stop into the 1.2 route.
                For testing, I created a new 1.2 route to simulate a real situation. When I was few miles from my test deviation, I did the "Up Ahead" thing, selecting the via point to route to. This time, I selected "create a new route" instead of modifying my 1.2 route. I pressed "Go", and my new route started guiding me. I got to the new destination without issue. While stopped, I brought my 1.2 route back up, and it immediately presented the starting point radio box. I selected 'Closest Enry Point", and off I went. Long story short, the remaining route continued exactly as originally planned. Success!
                I love it! No skipping waypoints or other stuff you have to deal with on the Next app. I'm now confident I can use 1.2 for just about any situation.
                • John S Parry John S Parry
                  Steve Jarrell
                  Steve Jarrell
                  Steve Jarrell
                  #102
                  @John-S-Parry Awesome!
                  That makes logical sense (that's not always the case with Garmin) 🙂 as the 1.2 gpx route has a LOT of gps coordinate pairs in it so when you selected "Nearest Point" it obviously guided you back to one of those points then you were on your way. That's the way that I was hoping that it worked.
                  Thanks very much for the update!
                  Steve Jarrell
                  2025 BMW R1300GS
                  2025 Can-Am Spyder
                  Garmin XT3
                  • Carl Lee
                    Carl Lee
                    Carl Lee
                    @steve-jarrell that was a huge typo on my part. It was meant to read “and even if you are not using Tread”. I must have been tired. I’m all Zumo’d out.
                    • Carl Lee Carl Lee
                      Steve Jarrell
                      Steve Jarrell
                      Steve Jarrell
                      @Carl-Lee Been there. Done that. Have the t-shirt! 🙂
                      Steve Jarrell
                      2025 BMW R1300GS
                      2025 Can-Am Spyder
                      Garmin XT3
                      • Carl Lee Carl Lee
                        @Carl-Lee said:
                        " I'd like to add something about recalculation. I haven't played with 'Up Ahead' places by inserting them into my route but on a normal deviation from a 1.2 route with recalculation left on, I've found there is a recalculation but it logically puts you back on your intended route - maybe with a u-turn or merging with it a little further along."
                        This got me thinking about recalculation to get the Zumo to return you to the route. So I had to go out and check.😊
                        You're correct that going off route, with recalculation left on, will simply attempt to return you to the route. It does not recalculate the whole route and trash your custom shaping up ahead. I performed conscious off-route deviations at least three separate times, and they all did nothing other than try to return me to the route. A few of the Zumo decisions on returning me were head scratchers, but they worked, and the route continued as normal.
                        The recalculations that are a NO-NO are actions that modify the route itself. As discussed, that can be through using "Up Ahead" and inserting a new via point as the next stop. Using Search to find a POI and inserting that via point as the next stop is equally disastrous. In short, don't do anything that modifies your route and triggers a recalculation.
                        From my perspective, using 1.2 GPX files in the Zumo works very well if you understand the behavior.
                          Steve Jarrell
                          Steve Jarrell
                          Steve Jarrell
                          @John-S-Parry "In short, don't do anything that modifies your route and triggers a recalculation."
                          I think that sums it up perfectly!
                          I leave auto-recalculation turned off just from habit using so many different versions of the Garmin, and I'd rather just get back on the route by myself, but off-route re-calculation does not seem to trigger the dreaded "ok, you changed the route manually so that gives me (the Garmin) permission to do whatever I want to to your route". 🙂
                          Steve Jarrell
                          2025 BMW R1300GS
                          2025 Can-Am Spyder
                          Garmin XT3
                          • Carl Lee
                            Carl Lee
                            Carl Lee
                            #107
                            Still some more testing to be done I think. I’m wondering if “shaping” the route on the Zumo just by adding some more shaping points (not vias) will damage it. In reality, this is something I would rarely, if ever, do but it would be nice to know.
                            When I get chance……
                            And anyway, even leaving auto recalculation off, if you’re struggling to get back on the route (it happens!), stopping it and restarting with CEP is a fine and still won’t destroy the route.
                            • Carl Lee Carl Lee
                              When I get chance……
                              Steve Jarrell
                              Steve Jarrell
                              Steve Jarrell
                              @Carl-Lee Yep, you're right. Restarting the route from any point is FAR better than doing ANYTHING that signals the Garmin that it's ok to change your route as it sees fit.
                              As far as adding the shaping points goes I really don't know. I've never done that as I've never had the need to do so. For that matter I've never created a route directly on the Garmin either, so for me there are still a lot of unturned stones! 🙂
                              Steve Jarrell
                              2025 BMW R1300GS
                              2025 Can-Am Spyder
                              Garmin XT3
                                @Steve-Jarrell Yes, it seems with a high degree of confidence, that 1.2 off-route recalculation does not seem to trigger a complete recalculation of the route. It's simply a re-calculation to get you back to the route. I don't think there is an overt amount of intelligence within the Zumo. In each case where I intentionally went off-route to trigger auto recalculation, it tried to turn me around back to the off-route spot for route re-entry. Even when there was a shorter re-entry point a little further up. In a way it makes sense, because it wants you hit all points on the route. But it's not always optimal if all you want is to get back to a point on the route as quickly as possible.
                                To the last observations made by @carl-lee, I don't know for sure if adding shaping points on the Zumo will destroy the route. But my best guess is that it will. I think that playing with the track sections of a 1.2 route, with adding either Shaping points or Vias, will communicate to the Zumo that all bets are off and trigger a total route recalculation.
                                Why do I say this? It's not 100% apples-to-apples, but when I export the track of a MRA route as a GPX and then import it into Garmin Basecamp, everything is fine after converting the Track to a Route. If at that point I try to make any modifications, either Shaping or Via, I get a BC warning message to the effect that a total recalculation will take place. I'm guessing this logic also applies to 1.2 routes on the Zumo. An example of Garmin being Garmin. 😊 It might be an interesting experiment to conduct, but someone else will have to pick up that torch.
                                • Mzokk
                                  Adding shaping points to the route on the Zumo will likely destroy the route as the complete route is recalculated to include the applied shaping point. When you convert a track to a route in Basecamp it gives a start and finish and includes any Via points. But on the XT at least if you go route and haven't switched off automatic recalculation it will recalculate the route on the zumo according to the preferences set. There is a way round this on Basecamp to force a track to create a load of shaping points but its not really relevant to an MRA discussion.
                                  • Mzokk Mzokk
                                    #111
                                    @Mzokk Thanks for the confirmation. I'm a simple man who doesn't want to get bogged down in the nuances of possible exceptions to what happens most of the time. In my short period of testing and use of 1.2 GPX routes, my firm conclusion is not to make any modifications that would trigger a route recalculation. Off-route recalculation for re-entry is OK, because the base route itself is not modified. My first instinct will still be to reenter a route under my own control, but the option for the Zumo to do that for you is clearly there.
                                    Everybody has their own approach to route planning/creation/execution. At a high level, my separation of duties is that all route modifications happen at the MRA Routeplanner level. If I want to make any Shaping/Via point changes, I go back to Routeplanner, perform the updates, and then re-copy the route back to the Zumo. In other words, Routeplanner is the repository for managing my routes. I have my own folder system for keeping everything sorted out. I view the Zumo as the execution layer. Similar in concept to the old IT Client/Server model. It's just one way of doing things, but it's a simple separation of duties and it works for me.
                                    As a side note, in being active on this forum, it seems like many members view routes as a "suggestion" that should be flexible to change through repeated skipping of waypoints. That seems to me where a lot of people get tripped up. I guess different views on things are what makes the world go around.
                                    • smfollen 0
                                      smfollen 0
                                      smfollen 0
                                      I'm new to MRA but I've been working to understand gpx and zumo for a long time. I think I can offer a bit of clarification here.
                                      From a zumo perspective, the key difference between MRA's 1.1 and 1.2 is not that shaping points are eliminated, but that route point extensions are included. They are essentially track points, just formatted and handled differently.
                                      If a route is transferred into the zumo without route point extensions (e.g. MRA's gpx 1.1), it will be calculated based on all available route points, both via and shaping. If the route does include route point extensions (e.g. MRA's gpx 1.2), it will not be recalculated unless the route is subsequently changed.
                                      If a route is fully recalculated by the zumo, the route point extensions are discarded, the route is calculated based on all available route points, both via and shaping. New route point extensions will be generated. Route point extensions are the result of route calculation, never an input to the calculation.
                                      When using CEP, or going off-route with recalculation allowed, the zumo will indicate that it is calculating, but is is not recalculating the entire route. It is only calculating a small route segment. Route point extensions are preserved.
                                      Adding or removing a route point, via or shaping, will result in a full route recalculation, discarding all previous route point extensions. Since MRA's 1.2 discards shaping points, only the via points are available to recalculate the route.
                                      This implies that it would be better to import a route which includes via, shaping, and route point extensions.
                                      I should also note that recent firmware version 6.60 for the zumo XT2 improved off-route recalculation behavior.
                                      Getting lost isn't always a bad thing.
                                      • smfollen 0 smfollen 0
                                        Steve Jarrell
                                        Steve Jarrell
                                        Steve Jarrell
                                        #113
                                        @smfollen-0 "From a zumo perspective, the key difference between MRA's 1.1 and 1.2 is not that shaping points are eliminated, but that route point extensions are included. They are essentially track points, just formatted and handled differently."
                                        Exactly! For the person who doesn't clearly understand this yet, this key difference is VERY important when the Garmin calculates the route. I'll illustrate here what happens during a 1.1 vs. 1.1 route import.
                                        Let's take a route created with created in MRA that includes 4 via points (starting via point + ending via point + 2 more) and 6 shaping points for a total of 10 total reference points as an example:
                                        In simple terms, a 1.1 route in the .gpx file looks like this:
                                        starting via point 1 -> shaping point 1 -> shaping point 2 -> via point 2 -> shaping point 3 -> shaping point 4 -> via point 3 -> shaping point 5 -> shaping point 6 -> ending via point 4.
                                        When this 1.1 route is imported into the Garmin it will calculates its own route using its own logic between each of these 10 shaping and via points based on its settings (fastest, shortest, etc). Many times that route doesn't go exactly where you planned or how it looked in MRA, and it does not match the track.
                                        On the other hand, a 1.2 route in the .gpx file looks like this
                                        (For simplicity's sake I'm going to refer to "route extensions" as "track points" as both of them are simply latitude/longitude pairs that are like breadcrumbs that precisely mark the desired path between two points.)
                                        starting via point 1 -> track points -> via point 2 -> track points -> via point 3 -> track points -> ending via point 4.
                                        When the route is imported there are no shaping points in the 1.2 .gpx format as you pointed out. Instead, the 1.2 route includes a large number (for a normal route many hundreds or even thousands) of track points that force the Garmin to calculate the route EXACTLY as you had planned and EXACTLY the same as your track file.
                                        Good discussion. Thanks for the input!
                                        Steve Jarrell
                                        2025 BMW R1300GS
                                        2025 Can-Am Spyder
                                        Garmin XT3
                                        smfollen 0 1 Reply Last reply
                                          smfollen 0
                                          smfollen 0
                                          smfollen 0
                                          @Steve-Jarrell said:
                                          Instead, the 1.2 route includes a large number (for a normal route many hundreds or even thousands) of track points that force the Garmin to calculate the route EXACTLY as you had planned ...
                                          Actually, for 1.2 the Garmin does NOT calculate the route (on import and for [some] off-route or Closest Entry Point cases). It just uses what was imported without change, which is why it matches the original.
                                          In cases where it does recalculate the 1.2 route, it would use only starting via point 1 -> via point 2 -> via point 3 ending via point 4. This is why, when a full route calculation occurs on the zumo, a 1.1 route with both via and shaping points would produce a result closer to the original than a 1.2 route.
                                          Which is why
                                          smfollen-0 said:
                                          ... it would be better to import a route which includes via, shaping, and route point extensions.
                                          • 4
                                          • 5
                                          • 6
                                          • 7
                                          • 8
                                          • 9
                                          • 10
                                          Stevedo 6 0
                                          Stevedo 6 0
                                          Andy Beviere
                                          Andy Beviere
                                          smfollen 0
                                          smfollen 0
                                          Will Brooks
                                          Will Brooks
                                          Steve Jarrell
                                          Steve Jarrell
                                          Carl Lee
                                          Carl Lee
                                          Simon James Hancock
                                          Simon James Hancock
                                          Phil Ellis
                                          Phil Ellis
                                          Jim Foster
                                          Jim Foster
                                          Sam Ellis
                                          Sam Ellis
                                          Papasmurf2
                                          Papasmurf2
                                          OkayJim
                                          OkayJim
                                          • Webapp-icoon
                                          • My feedback on the AI planner
                                          • Trip - 🌙 Where do you sleep?
                                          • Groeten uit Alphen aan den Rijn
