  4. Multiple markers placed, no route produced.
4 Posts 3 Posters 303 Views 1 Watching
  • Andrew Wright 1 0 Offline
    Andrew Wright 1 0
    Hi. I have started a route for a European tour. However I got to day 4 (so far Gloucestershire - Calais - Kogenhiem) and the software has stopped calculating a route. Any ideas? Thanks.
    Nick Carthew Bouke Ent 2 Replies Last reply
    • Andrew Wright 1 0 Andrew Wright 1 0
      Nick Carthew Offline
      @Andrew-Wright-1-0 I suspect that you are using the planning map from OpenStreetMap (OSM). The OSM map doesn’t like long routes. Either split your route into individual daily routes or change the planning map.
        It is important to use the correct planning map for your navigation device.
        Each planning map comes with its own set of algorithms embedded within the map data to calculate which roads to use.
        The algorithms are unique to each planning map.
        After choosing the planning map you can also click Always use this map for new routes to set that map as your default planning map.
        From now on all new routes will be created using the chosen planning map.
        My screenshot below shows the planning map from HERE is selected and also the option to Always use this map for new routes.
        The overlay maps are separate to the planning maps and have no effect on route calculations.
        Think of them as clear sheets with extra information that you place over the top of the planning map.
        The planning map underneath does all of the route calculations.
        So with the planning map selected you can then use any of the overlay maps.
        If you do not see the same blue menu bar with the planning maps that is shown in my screenshot, click Page menu first and then all of the same options will be available to you.
          Bouke Ent Offline
          Bouke Ent Offline
          i made a overview route with 10k km.
          but there are limits like max point and how you use routing and exeption. like no highways and shortest. they limit range.
          also arround 200 points is max.
          better is to make route every day and then keep it under 150 point.
          Andrew Wright 1 0
          Andrew Wright 1 0
            255
            siebo vd berg
            siebo vd berg
            504
          • Transport modes?
          • MRA 5.2.2 (489) Avoidances are not taken into account///Vermeidungen werden nicht berücksichtigt
          • No navigation instructions
            Hans-Udo Erdmenger
            Hans-Udo Erdmenger
          • Google maps and Streetview
            Stevedo 6 0
            Stevedo 6 0
