  2. Routes & Tracks
  3. Route made through roadworks and blocked roads
9 Posts 6 Posters 508 Views 2 Watching
  • Metalheadundefined Offline
    Metalhead
    wrote last edited by
    When planning a round trip in the app, a nice route was made with 2 known route violations. Both were blocked roads due to roadworks. The mra said sent me over this road, did not provide a d-tour when we saw we could not pass and then it kept on sending us back to the same place knowing we could not pass. This was very annoying.
      Maybe the new update will also work. In that update is a route block possibility
      • Metalheadundefined Metalhead
        wrote last edited by Con Hennekens
        @Metalhead, the app will not send you back because of the blocked road, but because of a missed track point. It will send you back maybe 2 or 3 times, and then give up.
        Metalheadundefined 1 Reply Last reply
        • Leike Lodiersundefined Online
          wrote last edited by Leike Lodiers
          Would be a nice option in the future to choose after how many reminders you want the route to go on. And standard set it to one so this questions never being seen again..πŸ˜‹ πŸ˜‹
            Metalhead
            @Con-Hennekens this is what I question.
            Why does it make a route through a well known roadblock?
            Why does it not offer an alternative?
            Why does ik keep on trying to get me back to the routepoint I supposedly missed for far longer than 3 attempts.
              The question is if that known roadblock is known at Here. Do you see that roadblock on your map. If not, it’s not known at Here.
                Metalhead
                The road block was visible in the map, the route info said there was a route violation due to the road block and the app kept telling me about the roadblock. The thing it did not do was not plan a route through the roadblock or provide an alternative.
                • Benjamin Ralstonundefined Offline
                  Benjamin Ralston
                  I've experienced this as well. During my long road trip last month there was at least one location where the app stated there was a known route violation road closure, yet it directed me through that violation anyway without offering a detour. I don't know if it would have tried redirecting me back through it, because I manually looked up the best detour route and changed the route to account for it.
                  • Herman Veldhuizenundefined Offline
                    wrote last edited by Herman Veldhuizen
                    I might be wrong but I think that MRA does this "by design", but only if you navigate a route as track.
                    The reason behind: Closures are temporary and MRA sort of assumes that by the time you start riding the closure should be gone. If not, follow the signs on the road to guide you around.
                    But there are 2 reasons why I think this is not how it should be :
                    1st : MRA cannot know when you start riding and simply cannot make any assumption about whether the closure is gone or not.
                    2nd : if the road is for example a mountain road then the detour starts long before the closure, there will be no signs for you to follow.
                    Navigating a route as route might help out here. but honestly I think that mra should reconsider the design too.
                    Benjamin Ralston
                    Metalheadundefined
                    Metalhead
                      Roland Busenhartundefined
                      Roland Busenhart
                      2.8k
                    • Crashes na update
                      Nick Carthewundefined
                      M. Schrijverundefined
                      Aiello antoninoundefined
                      28
                      46
                      3.0k
                    • Doe ik iets verkeerd of...
                    • test Myroute APP
                    • Starting navigation in the middle o the programmed Route.
