  4. Different route guidance between the route lab and the MRA route planner
10 Posts 6 Posters 1.2k Views 4 Watching
  • Reinhard Punz
    Reinhard Punz
    Reinhard Punz
    I've noticed that the MRA Route Lab and the MRA Route Planner use different routing data. I still prefer planning with the Route Lab because it's clearer for me. When I later open a route in the MRA, the planned route is displayed correctly, but as soon as I click "edit" or "navigate," the route can change. In my specific case, this is a problem because the MRA Route Planner (and therefore the navigation app) is providing incorrect data. This has led me astray several times recently. How can this be resolved?
    • Hubert Thoring
      Solution: in the route planner...
      • Activate traffic data
      • Disable seasonal lockdowns
      This is how the route planner behaves exactly like the app, I suspect construction sites or seasonal closures on the route ...
      Lösung: im Routenplaner…
      • Verkehrsdaten aktivieren
      • Saisonale Sperrungen deaktivieren
      So verhält sich der Routenplaner genau so wie die App, ich vermute Baustellen oder Sperrungen Saisonal auf der Strecke …
      iPad 9. G iOS 27.2.1/iPhone 16e iOS 27.2.1/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
      Lluis Arasanz Reinhard Punz 2 Replies Last reply
        @Hubert-Thoring
        Yes, both modules has different configurations for routing and I always deactivate seasonal closures when planning.
        but... Perhaps you mean "RouteLab" and not "RoutePlanner", isn't it?
        At least, the images provided to deactivate seasonal closures and traffic layer are from RouteLab (WebPlanner)
        • BMW F750GS
          Reinhard Punz
          Reinhard Punz
          Reinhard Punz
          @Hubert-Thoring Thank you for the detailed response. I have now traced the steps and, for testing purposes, disabled the "Deactivate seasonal closures" option in the web planner; this yielded the same result as in the Android app. However, the result is incorrect. There is no seasonal closure or (total) closure in that area. It is unfortunate that the Android app does not respond when enabling or disabling seasonal closures; in either case, it always produces the same incorrect result.
          Vielen Dank für die ausführliche Antwort. Ich habe das jetzt nachvollzogen und im Web-Planer den Menüpunkt "Saisonale Schließungen deaktivieren" testweise deaktiviert und kam damit zum selben Ergebnis wie in der Android App. Jedoch ist das Ergebnis falsch. Es gibt in dem Gebiet keine saisonale Schließung und es gibt keine (Total)sperre. Schade ist, dass die Android App nicht reagiert, wenn man Saisonale Schließungen aktiviert oder deaktiviert. Es kommt in diesem Fall immer dasselbe falsche Ergebnis heraus.
          • RetiredWingMan
            Are you using the Here maps in routelab?
            Reinhard Punz 1 Reply Last reply
              There seems to be some road closures on the stretch from Joachimsberg to Sankt Anton.
                Reinhard Punz
                Reinhard Punz
                Reinhard Punz
                @M.-Schrijver Yes, the image looks like it. There was indeed a road closure there at one time, but it's long since been lifted. I use the HERE map for route planning in the Route Lab (website), which is already up-to-date in that area. The data in the Android app seems to be outdated. It's a problem when you plan a route and the navigation system shows a different way. As I understand it, the web planner and the Android app should use the same map data.
                Ja, die Abbildung sieht danach aus. Es gab dort tatsächlich einmal eine Straßensperre, die aber schon lange nicht mehr aktuell ist. Ich verwende im Routen Labor (Website) die HERE Karte für die Planung, die ist in dem Bereich bereits akutell. Die Daten der Android App scheinen veraltet zu sein. Es ist halt ein Problem, wenn man ein Route plant, und das Navi einen anderen Weg anzeigt. Die Web-Planer und die Android App sollten nach meinem Verständnis dasselbe Kartenmaterial verwenden.
                  Reinhard Punz
                  Reinhard Punz
                  Reinhard Punz
                  @RetiredWingMan Yes, I use HERE maps for planning.
                  • Reinhard Punz
                    Reinhard Punz
                    Reinhard Punz
                    I've found the best solution for myself: If I know a route is open and MyRouteApp displays it differently, I now use the "Track Navigation" function in the navigation settings. While I would prefer it to work via "Route Navigation" as well, I have little control over the data as a user. I did find a way to report map errors to HERE, which works, but the planner integrated into the MRA uses different data.
                    Ich habe für mich die beste Lösung gefunden: Wenn ich von einer Strecke weiß, dass sie offen ist und MyRouteApp das anders anzeigt, verwende ich nun bei den Navigationseinstellungen die Funktion "Track-Navigation". Es wäre mir zwar lieber, wenn das auch über "Routen-Navigation" funktionieren würde, aber auf den Datenstand habe ich als Benutzer nur wenig Einfluss. Ich habe zwar eine Möglichkeit gefunden Kartenfehler bei HERE zu melden, was auch funktioniert, aber der in der MRA integrierte Planer verwendet abweichende Daten.
                    BMcG 1 Reply Last reply
                    • Reinhard Punz Reinhard Punz
                      BMcG
                      BMcG
                      BMcG
                      wrote on last edited by BMcG
                      @Reinhard-Punz I think the system is working pretty much as intended
                      Any avoidance setting set in the MRA web planner is set the same in the MRA app for that route,
                      the settings are part of the route & are synchronised in your account
                      When planning if you want to ignore road closures then "Disable Seasonal Closure" option should be enabled
                      this way you can plan the path you want to take regardless of what the road situation maybe today,
                      in 6 months or a year from now
                      The term "Seasonal" is a poor description of what the function does, originally it was for winter high mountain passes but its function has been expanded so now it also ignores temporary road closures
                      If in the navigation app you decide to be online allow traffic aware route calculations of course the app will recalculate the route with the current data it has available
                      As you have correctly discovered if you want to ride a route exactly as you have planned then you have to ride the path as a track & for complete peace of mind be in offline mode, that way nothing can interfere with your plan
                      If you want to ride as a route then your open to changes being made to the planned path
                      You cant blame the app for doing what you tell it to do
                      In your settings you may find it useful to enable the function "Navigation Settings > Screen Layout > Lines > Show Original Route"
                      This displays a white line of the original route/track on the background of the map so you can easily see where the directional path is deviating from the original planed path
                      Reinhard Punz
                      Reinhard Punz
                      BMcG
                      BMcG
                      • Online map settings
                        MartinW
                        MartinW
                      • Real-time traffic
                        Òscar
                        Òscar
                        Andy Nicholson
                        Andy Nicholson
                      • HERE map not calibrated
                        MartinW
                        MartinW
                      • Myrouteappstay
                        Bé Jeuring
                        Bé Jeuring
                      • Navigatie met DMD tablet
                      • Show on the maps's button
