  4. Different route guidance between the route lab and the MRA route planner
5 Posts 4 Posters 85 Views 2 Watching
  • Reinhard Punzundefined Offline
    Reinhard Punz
    wrote last edited by
    I've noticed that the MRA Route Lab and the MRA Route Planner use different routing data. I still prefer planning with the Route Lab because it's clearer for me. When I later open a route in the MRA, the planned route is displayed correctly, but as soon as I click "edit" or "navigate," the route can change. In my specific case, this is a problem because the MRA Route Planner (and therefore the navigation app) is providing incorrect data. This has led me astray several times recently. How can this be resolved?
      Solution: in the route planner...
      • Activate traffic data
      • Disable seasonal lockdowns
      This is how the route planner behaves exactly like the app, I suspect construction sites or seasonal closures on the route ...
      Lösung: im Routenplaner…
      • Verkehrsdaten aktivieren
      • Saisonale Sperrungen deaktivieren
      So verhält sich der Routenplaner genau so wie die App, ich vermute Baustellen oder Sperrungen Saisonal auf der Strecke …
      Lluis Arasanzundefined Reinhard Punzundefined 2 Replies Last reply
        Lluis Arasanzundefined Offline
        @Hubert-Thoring
        Yes, both modules has different configurations for routing and I always deactivate seasonal closures when planning.
        but... Perhaps you mean "RouteLab" and not "RoutePlanner", isn't it?
        At least, the images provided to deactivate seasonal closures and traffic layer are from RouteLab (WebPlanner)
        • BMW F750GS
          Reinhard Punz
          @Hubert-Thoring Thank you for the detailed response. I have now traced the steps and, for testing purposes, disabled the "Deactivate seasonal closures" option in the web planner; this yielded the same result as in the Android app. However, the result is incorrect. There is no seasonal closure or (total) closure in that area. It is unfortunate that the Android app does not respond when enabling or disabling seasonal closures; in either case, it always produces the same incorrect result.
          Vielen Dank für die ausführliche Antwort. Ich habe das jetzt nachvollzogen und im Web-Planer den Menüpunkt "Saisonale Schließungen deaktivieren" testweise deaktiviert und kam damit zum selben Ergebnis wie in der Android App. Jedoch ist das Ergebnis falsch. Es gibt in dem Gebiet keine saisonale Schließung und es gibt keine (Total)sperre. Schade ist, dass die Android App nicht reagiert, wenn man Saisonale Schließungen aktiviert oder deaktiviert. Es kommt in diesem Fall immer dasselbe falsche Ergebnis heraus.
            Are you using the Here maps in routelab?
            Reinhard Punz
              Roland Busenhartundefined
              Roland Busenhart
              2.8k
            • Crashes na update
              Nick Carthewundefined
              Aiello antoninoundefined
              28
              46
              3.0k
            • Doe ik iets verkeerd of...
              Herman Veldhuizenundefined
            • test Myroute APP
            • Starting navigation in the middle o the programmed Route.
