  3. Selection of vehicle
2 Posts 2 Posters 240 Views 2 Watching
  • Peter Schiefer Offline
    Peter Schiefer
    Dear Corjan and Team,
    You now offer in MRA the opportunity to select different vehicle modes.
    From motorbike, to car, motorhome, caravans, trucks and new, BEV.
    Problem as like in the past, you can only store in your personal database, membership data one vehicle and select the type.
    When you now like to change the vehicle, you must open your account change the vehicle and save the data.
    It will be a big advantage when we could save more than one vehicle or select minimum the vehicle type prior to the planninng of a route on the main page.
    Peter
    Brian McG 1 Reply Last reply
    • Peter Schiefer Peter Schiefer
      Brian McG Offline
      Brian McG Offline
      @Peter-Schiefer the option in your account page is the "default" type that is used when you create a route
      Once a route is created the vehicle type can be changed for each & every route
      You just need to go to the "Route Information" section on the route & change the "Transport Mode" or "Travel Mode"
      Peter Schiefer
      Peter Schiefer
      • MRA groups
      • POI naming/text display
        464
      • Stemgeluid sterker bij afspelen muziek
      • GPX1.2 & Garmin Tread
        MTC-Zeilberg
        MTC-Zeilberg
      • scenic routes maken werkt niet
      • Folders that can store tracks and waypoints
        martin-phogel.de
        martin-phogel.de
