  3. Best way to set my Garmin Zumo XT to play well with the MRA?
16 Posts 9 Posters 1.8k Views 6 Watching
    The best way, I found out is to make the route in MRA and export it as GPX 1.1 (route, track, poi).
    Then use the "good" old Basecamp and import this file. you will see now in Basecamp the track and a route existing of straight lines.
    Now open the route and let Basecamp recalculate. You'll find out that the route now follows more or less the track which is also visible in Basecamp .
    Manualy put in extra waypoint to make the route follow the track exact.
    There is no standard setting to avoid this problem.
    After that you can connect the GPS to your computer and in Basecamp, with a left click on the map existing the track and route you get an option to send it direct to the GPS.
    This is the most solit way.
    Stevedo 6 0 1 Reply Last reply
    • Mzokk
      Nope you don't need to put the additional unnecessary step of exporting to Basecamp. Just create the route with plenty of shaping (teardrop) points between Via(hand) points and download the file as gpx1.1 and send it via your phone using Garmin Drive. You can also use GPX 1.2 but if you do switch off auto recalculate......or the Garmin will take you straight to the end.
      • Guzzist
        That is the issue with every Route planner, sending the route to another navigation app/device. Each has it's own algorithm. So it's nearly impossible, to setup on each end the same settings. The only way is, to enter "enough" route points during planning, to force navigation apps/devices to use exactly that roads you have planned.
        But as @hubert-thoring said: Garmin devices has limited capacity for work with via points (route points). But you can work in MRA with shaping points, which are also route points (with some differences in the effect).
        • Mzokk
          The Zumo XT can handle 30 via (stop points) and 125 shaping points between each via point. So plenty for most purposes. Tracks cancelled have 10,000 points.
          • AWDC LAO
            Garmin has also an APP : TREAD for the XT2/3, or do you have XT1 ?
            a white mouse on the motorbike Guzzist 2 Replies Last reply
            • AWDC LAO AWDC LAO
              I haven't heard much good about it. Especially when it comes to importing routes
                Stevedo 6 0
                Stevedo 6 0
                Stevedo 6 0
                @white.mouse
                This is exactly the process I follow on my Garmin Zumo 595. It's a little tedious but does guarantee that the route I meticulously planned in MRA route planner is followed on the 595.
                • Mike wiruth Mike wiruth
                  Hello all, I'm looking for advice for setting up my Garmin Zumo XT. I plan my routes with the desktop app and then I transfer the gpx file to my garmin. For those that do the same, can you advise me on the settings for my garmin so it will not change my route that was sent from the MRA app. The last big trip I took my garmin would try to change the route and not match what was on my phone with the MRA. Has anyone else had this problem. I like to run them both as it seems easier to search things on my zumo.
                  Thanks for any help you can give me.
                  Mike
                  @Mike-wiruth as @guzzist suggests use lots of points to constrain the route to the path that you want to take
                  on the web planner you definitely want to be using "Compare" tool to ensure that OpenStreetMap & TomTom also follow the same path that Here is calculating in the MRA web planner
                  if TomTom or OpenStreetMap can find an alternative path you can bet that your XT will also find a different path to what you had planned
                  the XT is using a different path calculator profile to MRA even though they are both using Here maps
                  so any calculation done by the XT is possibly going to be different unless you force (constrain) it to the same path with as many points as it takes
                  & again as @guzzist says you have to make sure the settings you have on the MRA planner match the settings on your XT as closely as you can
                  a rough guide that paths are closely matching is to make sure the mileage for the path in MRA is similar to the path on the XT
                  it is not a perfect check but if the variation is small, chances are more likely the paths are more similar
                  it is a lot of work trying to coral an XT to stick on a path you want to go & ultimately the XT will defeat you
                  you will be taken off your chosen path, I know from bitter experience
                  yes the search & poi capabilities on a Garmin are far better than MRA, especially when it comes to things like finding petrol
                  but I would rather my navigation device actually navigates exactly the path I want to go (MRA navigation does this) & sacrifice the nice feature of being able to find restaurants or hotels etc
                  after all we do have google for that sort of thing
                  & as @mzokk you dont need to pass the mra file through basecamp, that fixes nothing
                  • AWDC LAO AWDC LAO
                    Folks, the issue is not the transmission method to the Garmin XT, nor the gpx file format! O.k. the file format has other issues in the Garmin device, but this is not the point in this discussion.
                    After transmit a route via gpx file to the Navi Device, it is starting the calculation, how to come from WP1 to the next WP. Yes, you can deny recalculation - but the first interpretation/calculation is necessary.
                    By the way: in many forum discussion (also in Garmin forum) users suggests not to use the bloody TREAD app...
                    And @mike-wiruth asked only why the planned route differs after transmission into the navi.
                      That is simply the only reason I still use Basecamp.
                      In all the time until now the route I check there (and if neccesary modify) has never been different in my XT1
                      • Travellexxie
                        Ok, let's hear another opinion 😆
                        1. Plan your route with enough waypoints
                        2. Export the route in 1.2 format
                        3. Transfer the route by cable/connector/wireless with drive/whatever to your XT and place the route in the GPX map
                        4. Import the route
                        5. Make the track visible on the map and make it wider
                        6. Set recalculation off
                        7. Start the route and enjoy😁
                        MRA Lifetime Gold
                        Stevedo 6 0
                        Stevedo 6 0
                        Mike wiruth
                        Mike wiruth
                          Floris v
                          Floris v
                          3.9k
                        • Altitude numbers size
                          JosepD
                          JosepD
                        • Seizoensafsluitingen
                        • Suggestion: Live location sharing for friends on the map
                        • 5 dagen Harz.. 2 problemen met AA
                        • Elektrisch voertuig
                          Arno van Lochem - Senior RX
                          912
