  4. Seasonal closures affect not only seasonal road closures (mountain passes and the like) but also closures due to roadworks. This is why the route takes you through the closure even during planning, even though Here is actually aware of it.
12 Posts 7 Posters 821 Views 4 Watching
  • Peter Zehentreiterundefined Offline
    I’ve noticed the following... when I plan a route and enable seasonal closures in the settings, the seasonal closures of the passes are taken into account, but the closures due to temporary roadworks are also ignored, and the route is strictly directed through the closure (even though the closure is known to Here)
    That’s why the route already takes you through the closure during planning, even though it’s actually known to Here.
    However, if I deactivate seasonal closures in the web planner, the roadworks are taken into account during planning and a detour is created at that stage.
    Is this a bug or is it intended behaviour?
    Ideally, roadworks closures should be treated separately from seasonal closures.
    When I open and start the route in the app, the app recognises that there is a closure, alerts me to this with a warning and also creates a diversion.
    Why does the behaviour differ between the website and the app?
    BMW R 1250 GS
    DMD-NOR7E 7"
    SPC Universal mount
    Motorola Edge 40 "offline"
    Sena SLR 3
    Sena 50 R
    • Jörgenundefined Offline
      That's what I would expect, too.
        Nice find
        I guess that one of the devs wel i comment on that
        • ginoginoundefined Offline
          ginogino
          I'd say the accuracy of seasonal closures and roadworks is correct in 3 out of 4 cases. On a road I used to travel a lot and which will now be closed for several months due to a landslide, myrouteapp web won't let me pass through it. On another road that passes through a mountain pass, it lets me pass through if I disable the seasonal closure, but that road isn't closed seasonally.
          I once happened to be driving a route I usually take and while navigating, myrouteapp next kept telling me to turn back. But since I'd driven that stretch of road a few days earlier and know it like the back of my hand, I thought myrouteapp next had crashed. Instead, I discovered that that day, and only that day, the road was closed.
          • ginoginoundefined ginogino
            @ginogino I realise that ‘seasonal’ road closures aren’t always handled 100% correctly, and I can always check elsewhere to see whether the road is open or not.
            What bothers me more, however, is that although the Here map in the web planner has marked the road closure due to roadworks, it still stubbornly routes me through the closure.
            The same route, when opened in the app, recognises the closure and immediately shows a possible detour.
            Why doesn’t this work in the web planner as well?
            BMW R 1250 GS
            DMD-NOR7E 7"
            SPC Universal mount
            Sena SLR 3
            Sena 50 R
            • Herman Veldhuizenundefined Online
              Chances are that when you use offline navigation the app works like the web based planner. But thats not what you want.
              My issue related to closures is in the app. How the app guides me through or around a closure seems to depend on:
              1. using online or offline maps/navigation
              2. which Navigate button I press (the other one is in the inapp-routeeditor)
              3. navigating a route as track or as route.
              I can understand 1 (when closures are recent and only available online) but not 2 and 3. I see this happening, even when I only use the app the make and navigate the route.
                This is know, and have never experienced it as a problem. It's actually nice to be able to disable a road closure when you see it is not there (anymore).
                Herman Veldhuizenundefined 1 Reply Last reply
                  @Con-Hennekens Do you have a link to some documentation if this is known? I searched and havent found it
                  Con Hennekensundefined Brian McGundefined 2 Replies Last reply
                  • Herman Veldhuizenundefined Herman Veldhuizen
                    @Herman-Veldhuizen, No I don't. But I have noticed before that disabling seasonal closures often leads to roadworks not being detoured. I think in the end a seasonal closure is a road closure too.
                      Brian McGundefined Away
                      @Herman-Veldhuizen & @peter-zehentreiter this is known functionality & can actually be quite useful
                      using the seasonal closure function has been recomended on this forum as an answer to actually enabling you to plan a route today through a closure, that you expect to be gone in a few weeks or months
                      the term "seasonal" is unfortunatley a bit missleading as the function really ignores a lot of closures
                      the term "seasonal" is probably a historical thing thats never been updated on the web planner
                      if you search the forum for "seasonal closure" I am sure you will find this is not new
                        @Brian-McG That the setting for seasonal closures can effect regural closures too is one thing. The fact that there are inconsistencies between the web and the app and in the app itself is another thing.
                        For example: When I make a route I spent most time in the inapp route editor (not the web based one) and expect the blue line which I see there to be the same when I press Navigate directly after. This wasn't the case when I last tried it.
                          ginogino
                          As mentioned, blocked roads aren't always reported. For example, in this case, myrouteapp web doesn't correctly let you pass through the blocked road:
                          This winter, there were heavy rains and many landslides, with roads closed for a short time or unfortunately for a long time, depending on the severity. So, when I plan a route this year, I first quickly trace it using Google Maps, which is generally much more accurate than myrouteapp when it comes to closed roads. Then, I recreate it in myrouteapp, making any necessary adjustments.
                          ginoginoundefined
                          ginogino
                          • erratic routing instructions
                          • how to view pictures of a structure or intersection
                            Jim O'Dowdundefined
                            Jim O'Dowd
                            white.mouseundefined
                            611
                            Massimo Cardoneundefined
                            Massimo Cardone
                            5.0k
                            Travellexxieundefined
                          • Is It Me?
                            D A Wakefieldundefined
                            D A Wakefield
                            371
                            Martin Garandundefined
                            Martin Garand
                          • Herberekenen werkt niet.
