  3. Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.
17 Posts 8 Posters 2.6k Views 3 Watching
  • David Rudgleyundefined Offline
    David Rudgley
    wrote on last edited by David Rudgley
    It's maybe that I'm doing something wrong when planning a route in MRA planner. But when I navigate any route but stop at a waypoint (shaping point) or an unscheduled stop, the route recalculates and tries to navigate me back to the Start Point. I have to pull over and using the Navigation app I edit the route by deleting all the waypoints I have already passed. Very frustrating and I end up having to import the route into the TomTom app and select drive to nearest point option when starting.
    Android Pixel 9 Pro XL
    TomTomGo as backup
    KTM 1290 Super Adventure S
    Quad Lock + Phone +Carpuride W702
    KTM 790 Duke
    Quad Lock + Phone
    • Spiliundefined Offline
      Spili
      wrote on last edited by Spili
      Agree.
      Have the same problem.
      Automatically should navigating to next waypoint. And I have to choose it manually.
      Not always "closest" means "next".
      There should be a choice for: "First unvisited" or just "Next"
      Automatically after stop should navigate to next, not to the start.
        Hello,
        What kind off operating system? Ios or Android?
        Do you have the latest version installed?
        David Rudgleyundefined 1 Reply Last reply
          Hello,
          David Rudgley
          @Hans-van-de-Ven-MRA-Master
          Android 11
          TomTomGo as backup
          KTM 790 Duke
          Quad Lock + Phone
          • David Rudgleyundefined David Rudgley
            @David-Rudgley Just like @Spili mentioned, when you restart the navigation after i.e. stop, you shall manually change the startling point of the navigation from "start of route" to "nearest waypoint". The app does not provide any messages or prompts about that, which on this forum has been commented on several times. Something for the future roadmap end of this year! 😀
              Do you close the app during the pause?
              David Rudgleyundefined Con Hennekensundefined 2 Replies Last reply
                David Rudgley
                @Hans-van-de-Ven-MRA-Master No, often it's me removing the phone from the mount with the app still running and turning the display off while it's either in my pocket of in storage
                TomTomGo as backup
                KTM 790 Duke
                Quad Lock + Phone
                  @Hans-van-de-Ven-MRA-Master said in Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.:
                  I recognize this. I am not sure if it has been corrected already, But I think that even with NOT closing the app, but just restarting the route, that option defaults back to "Beginning of route". I have made comments about this before, to make that option an application option instead of a route option (that seems to be not permanently).
                  Kudeeundefined 1 Reply Last reply
                    Kudeeundefined Offline
                    Kudee
                    @Con-Hennekens When you restart the route, the app will take you to the first point. However, you can see where you are and then select the next WP via "Edit route settings" as explained above. Maybe later it will be possible to select the WP directly. lg Kudee
                    • Kudeeundefined Kudee
                      David Rudgley
                      @Kudee I will be using the app again on a tour this coming weekend so I will use the route option navigate to closest WP or specific WP # and load the maps into TomTom Go as a back up
                      TomTomGo as backup
                      KTM 790 Duke
                      Quad Lock + Phone
                        @Kudee said in Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.:
                        Yes, that's what I am saying. So the option that says "start at closest waypoint" is not permanent, and therefore meaningless. It should be an application-options, not a route-option and certainly not one that defaults back to what you did not choose before.
                        Albert Rentingundefined 1 Reply Last reply
                          Albert Rentingundefined Offline
                          Albert Renting
                          @Con-Hennekens What I do during a stop for lunch or whatever other reason is pause the route and when I continue just touch the screen to restart and the route is displayed exactly where it was paused.
                          I don't stop the route or anything, just pause it and it works fine for me everytime.
                          • Roundaboutundefined Offline
                            Roundabout
                            When using a ride I made, saved as a Harley GPX, and then use in a Harley Boom Box and I have this problem, when I get back on bike I look for the ride in the boom box, find the ending waypoint and click on it and it works every time
                            • Albert Rentingundefined Albert Renting
                              @Albert-Renting said in Frustrating MRA Navigation App - tries to navigate me back to the start if I stop.:
                              I tend to check the route, where we are exactly and where shortcuts or detours are possible. Therefore it is not possible to not stop the route. You should be able to restart aroute given the available options to do so, but they do not work as intended. That's called a bug 😉
                                Albert Renting
                                @Con-Hennekens Even then it is possible. Start the desired route and then skip to the next waypoint from the location where you are at and you will be guided first to that next waypoint and then the route will be followed.
                                  @Albert-Renting, Yes Albert, but that is not what you would expect from a feature called "Start at closest waypoint" now, is it? I have been using Navigation from the get go, so I know how it works 😉
                                    David Rudgley
                                    This wouldn't be an issue if the App was stable, reliable and didn't reset the route numerous times during a ride. I will continue to use TomTom Go app until I can be confident that these issues have been fixed, fingers crossed that the new version of the MRA Navigation App is an improvement on the current build.
                                    TomTomGo as backup
                                    KTM 790 Duke
                                    Quad Lock + Phone
                                    Kudeeundefined
                                    Kudee
                                    Albert Renting
                                    David Rudgley
                                    Spiliundefined
                                    Spili
                                    Roundaboutundefined
                                    Roundabout
                                    • vraagje over route uit bibliotheek
                                      white.mouseundefined
                                    • ik zoek het goede adres bij soesterberg entree 4 van park vliegbasis
                                      Ralph Janssenundefined
                                      Ralph Janssen
                                    • Start route bij dichtstbijzijnde routepunt werkt niet
                                    • Zoom functie in carplay werkt niet ondanks goede settings
                                    • schaal bij gebruik navigatie op de gsm
                                      Peter Zehentreiterundefined
                                    • MyRoute-app wedding
                                      Jan 50undefined
                                      Jan 50
                                      24
                                      35
                                      1.0k
                                    • route overbrengen naar BMW Navigator 5
                                      540
