  4. Traffic info when planning with MRA
7 Posts 5 Posters 1.1k Views 3 Watching
  • Boštjan Kreutz
    Boštjan Kreutz
    Boštjan Kreutz
    Hello. I am just wondering if this is an error or something, that is so by-design. I was creating a route with MRA Gold membership, HERE maps and traffic info, and I know for fact, that this highway exit is closed due some constructions work. But MRA doesn't show this. Google maps knows that the exit is closed and put my route on some other exit.
    Does MRA only know traffic when navigating with NEXT?
    Because I am pretty sure that last year the MRA knew that one of the passes in Italy was closed due some work and it didn't let me plan my route there.
    MRA:
    Google maps:
    Brian McG Guzzist 2 Replies Last reply
    • Marinus van Deudekom
      It all depends on the info that Here gets regarding road works
      • Boštjan Kreutz Boštjan Kreutz
        MRA:
        Google maps:
        @Boštjan-Kreutz unfortunately MRA is only as good as the data it is given to work with
        In this case Google & TomTom know & show the closure
        Here does not seem to know about the closure on either HereWeGo or HereMapCreator
        You could report the closure to Here maps at HereMapCreator but whether the map update would make it into MRA before the bridge is reopened I do not know
        Accessing Here's live traffic updates is I believe a paid for service, it is not something that is readily available to the public, so I can't say why the closed bridge is not showing on Here's traffic data
          MRA:
          Google maps:
          @Boštjan-Kreutz ...it's not enough to use HERE map layer! You need to use HERE routing engine at first!
          Boštjan Kreutz 1 Reply Last reply
          • Guzzist Guzzist
            Boštjan Kreutz
            Boštjan Kreutz
            Boštjan Kreutz
            @Guzzist thank you for your answer.
            I am not sure I understand what you mean... I already started the route planning and created several way points...
              @Boštjan-Kreutz said in Traffic info when planning with MRA:
              That’s fine. You can carry on with the route you’ve started, but first you should set the Here map as your default map, if you haven’t already done so.
              The MRA navigation app uses only Here Maps for navigation, so it is important that the map used for planning matches the one used for navigation.Screenshot 2026-04-20 090205.png
              The other maps are simply there to help you choose a map that you personally prefer or find easier to navigate when planning your route.
              As not all map providers use exactly the same map data, please note the following!
              If you select a different map here in the layer, you must switch back to the Here map at the end of your planning and place all your waypoints precisely on the road.Screenshot 2026-04-20 091541.png
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Motorola Edge 40 "offline"
              Sena SLR 3
              Sena 50 R
                Boštjan Kreutz
                Boštjan Kreutz
                Boštjan Kreutz
                @Peter-Zehentreiter Thank you for that, but yes. I already knew about this and I am using HERE as default map and also when planning the routes. It is a must-have to use the MRA routes with my Garmin Zumo XT.
                Boštjan Kreutz
                Boštjan Kreutz
                  Kevin Bird
                  Kevin Bird
                  20
                  186
                • Statement on map spinning
                  17
                  36
                  3.5k
                • Change route color
                • wat is het verschil tussen het initial scherm en Free Ride in Android Auto
                • First time version 6 and AA
