  4. Problems with DIY POI Files
15 Posts 7 Posters 2.9k Views 6 Watching
  • Jörgen
    Maybe someone with success, can sent me a csv file for testing.
    • Mzokk
      I have one for Irish Photo Rally waypoints but I don't have enough privileges to upload it here.
      • Jörgen Jörgen
        @Jörgen, Found it!
        You need to swap lat/lon 😉
        The POI actually do import, on the other side of the globe... 😉
        (actually they don't, they are not valid coordinates)
        Try this:
        6.615499,51.225800,"Am Schulzentrum Kaarst","Forum"
        • Jörgen
          Hi Con, you're a genius—how did you figure that out?
          I never would have guessed that.
          Why “Latitude, Longitude” in MRA?
          That's a bug in MRA, right?
          Google uses that format too—“Longitude, Latitude”
          By the way, my POIs where in the Arabian Sea, just off the coast of Somalia.
          I would never have found that.
          • BertM
            This is the case already for a long time...
            It took me also some time to figure that one out.
            In my POI conversion tool I even made a special "MRA CSV export" to deal with this.
            I think it is by design as the GPX export is also the same
              Latitude / Longitude is the human friendly way.
              Longitude / Latitude is the mathematically correct way.
              This isn't a bug. It's a poor design choice perhaps from very long ago.
              But changing that now will cause more hassle than leaving it as is.
              Jörgen 1 Reply Last reply
              • Jörgen Jörgen
                @Jörgen, While I do not have a photographic memory whatsoever, I am a sucker for futile information... 😉 While testing your POI line I remembered an earlier conversation about this, that makes it less futile information 😉
                What your exercise reveals, is that CSV files are not the prefered way of exchanging POI (or anything really) because columns have no designation (top row with column names) and fields can be broken simply when they contain a , ...Why not use GPX instead?
                  @Corjan-Meijerink said in Problems with DIY POI Files:
                  Maybe this should be mentioned in the manual. 😊
                  • Jörgen
                    By the way, I got the information from here:
                    https://forum.myrouteapp.com/topic/5496/poi-file-format/2?_=1775682028073
                    So therefore, it is also wrong and need to be changed.
                      @Con-Hennekens said in Problems with DIY POI Files:
                      Just wanted to add some addresses from Google Maps, via Excel, into MRA.
                      This was the quickest way without using extra tools.
                      Anyway, I know now how to.
                      Thanks!!!
                      BMcG 1 Reply Last reply
                      • Jörgen Jörgen
                        Thanks!!!
                        BMcG
                        BMcG
                        BMcG
                        @Jörgen if you had saved/exported a POI from MRA yopu could have inspected the file to get the format
                        @Con-Hennekens CSV is the standard format for POI even MRA uses it to export 😉
                        • BMcG BMcG
                          @Brian-McG, MRA uses GPX too. My point is that fields in a CSV have no designation. In GPX (which is XML) they do.
                          BMcG
                          BMcG
                          • MRA 6.0.0 (532) Display schaltet um auf Standby?
                          • Route probleem
                          • issue when downloading a route and importing the file back into planner:
                            Parantapa
                            Parantapa
                            Andy Nicholson
                            Andy Nicholson
                          • F036 Fuel warning at 70 km with "No vehicle" displayed?
                          • In camper stand kan je niet naar openstreetmap
                            Nico bogerd
                            Nico bogerd
