  4. Problems with DIY POI Files
15 Posts 7 Posters 981 Views 6 Watching
  • Jörgenundefined Offline
    wrote last edited by
    Hi,
    I can't get the POIs displayed from a self-made POI file.
    I generated a CSV file like this:
    51.225800,6.615499,"Am Schulzentrum Kaarst","Forum"
    Longitude, Latitude, “POI Name”, “Description (optional)”
    Made sure that all information is separated by a comma.
    I can import the file in MRA, choose a symbol, and when activated, nothing is displayed.
    What is wrong?
    • Herman Veldhuizenundefined Offline
      when I tried it I had to zoom in on the map to see them.
      • Herman Veldhuizenundefined Herman Veldhuizen
        @Herman-Veldhuizen said in Problems with DIY POI Files:
        I know this. For control, I activated other POIs, to see the min. zoom factor.
          Maybe someone with success, can sent me a csv file for testing.
          • Mzokkundefined Offline
            I have one for Irish Photo Rally waypoints but I don't have enough privileges to upload it here.
            • Jörgenundefined Jörgen
              wrote last edited by Con Hennekens
              @Jörgen, Found it!
              You need to swap lat/lon 😉
              The POI actually do import, on the other side of the globe... 😉
              (actually they don't, they are not valid coordinates)
              Try this:
              6.615499,51.225800,"Am Schulzentrum Kaarst","Forum"
                Hi Con, you're a genius—how did you figure that out?
                I never would have guessed that.
                Why “Latitude, Longitude” in MRA?
                That's a bug in MRA, right?
                Google uses that format too—“Longitude, Latitude”
                By the way, my POIs where in the Arabian Sea, just off the coast of Somalia.
                I would never have found that.
                • BertMundefined Offline
                  This is the case already for a long time...
                  It took me also some time to figure that one out.
                  In my POI conversion tool I even made a special "MRA CSV export" to deal with this.
                  I think it is by design as the GPX export is also the same
                    Latitude / Longitude is the human friendly way.
                    Longitude / Latitude is the mathematically correct way.
                    This isn't a bug. It's a poor design choice perhaps from very long ago.
                    But changing that now will cause more hassle than leaving it as is.
                      @Jörgen, While I do not have a photographic memory whatsoever, I am a sucker for futile information... 😉 While testing your POI line I remembered an earlier conversation about this, that makes it less futile information 😉
                      What your exercise reveals, is that CSV files are not the prefered way of exchanging POI (or anything really) because columns have no designation (top row with column names) and fields can be broken simply when they contain a , ...Why not use GPX instead?
                        @Corjan-Meijerink said in Problems with DIY POI Files:
                        Maybe this should be mentioned in the manual. 😊
                          By the way, I got the information from here:
                          https://forum.myrouteapp.com/topic/5496/poi-file-format/2?_=1775682028073
                          So therefore, it is also wrong and need to be changed.
                            @Con-Hennekens said in Problems with DIY POI Files:
                            Just wanted to add some addresses from Google Maps, via Excel, into MRA.
                            This was the quickest way without using extra tools.
                            Anyway, I know now how to.
                            Thanks!!!
                              Thanks!!!
                              Brian McGundefined Offline
                              #14
                              @Jörgen if you had saved/exported a POI from MRA yopu could have inspected the file to get the format
                              @Con-Hennekens CSV is the standard format for POI even MRA uses it to export 😉
                              Normaly navigate Routes in Offline mode with Offline Maps
                                @Brian-McG, MRA uses GPX too. My point is that fields in a CSV have no designation. In GPX (which is XML) they do.
                                BertMundefined
                                Mzokkundefined
                                • New beta! 5.1 (457)
                                  Bart De Medtsundefined
                                  155
                                • V5.1.0 - 458 Beta Duplication of Speed Indicators - CarPlay
                                  Dave J 0undefined
                                  David Howarthundefined
                                  David Howarth
                                • V5.1.0 - 458 Direction Indicators Remaining on Map After Cleared Route - CarPlay
                                • Offline Navigation
                                  pjwood249undefined
                                  pjwood249
                                • V5.1.0 - 458 Request for Order of Settings - CarPlay
                                • Use GPX Format 1.1 for export
