  4. Route planner waypoint removal bug
11 Posts 6 Posters 3.0k Views 3 Watching
  • stuart marritt
    stuart marritt
    stuart marritt
    Hi guys
    Loving the new update to the route planner I was only saying to someone I find it difficult to plan route on a mobile phone and now this! Best update yet for me.
    Anyway I have found a minor bug
    If you are planning a route then change your mind and click undo to remove a waypoint the app doesn't renumber the next point in order
    For example I added 7 way points then changed my mind and clicked undo to remove two
    The next waypoint number was number 8 rather than following the flow and being number 6
    Thanks
    Stu
      Hi guys
      Thanks
      Stu
      @stuart-marritt Gosh, I can confirm the behaviour. Screenshot_20240717-233544.jpg
      Numbering 1:3, 6:8 after I undid placement of 4:5 and kept going on until the shown 8.
      • Corjan Meijerink Corjan Meijerink moved this topic from [Web] Problems, Bugs and other Issues on
        Thanks for sharing! Great to hear you are enjoying the update 🙂 This will definitely be fixed soon!
        Sorry for the minor inconvenience, enjoy the rest 😃
        • Con Hennekens
          Good to see it renumbers the waypoints once saved en loaded.
          stuart marritt 1 Reply Last reply
            stuart marritt
            stuart marritt
            stuart marritt
            @Con-Hennekens good spot!
            As above once you have saved the route it renumbers all the points so they are in order
            Although it would still be good if it did it as you was building the route as you may put a point in you want to stop at remembering the number but it will change when saved
              @stuart-marritt, of course! Corjan already promised to fix it 😉
              I was just trying this, because it could well be a problem while navigating if WPs did not follow up. Luckily that's not the case.
                Thanks, fixed in the upcoming update! 🙂
                • Mike 4b
                  Mike 4b
                  Mike 4b
                  Hi .I"m importing gpx files into MRA that have many waypoints . How do I reduce the number of waypoints ? Currently I can only delete one at a time .
                  • b0hd1
                    wrote on last edited by b0hd1
                    Creo que esta funcion es la que buscas.
                    Saludos!
                    • https://t.me/MRa_by_b0hd1
                    • YouTube: @demco17
                    • b0hd1 b0hd1
                      Saludos!
                      @b0hd1 said in Route planner waypoint removal bug:
                      Of course we value your input, but would you be so kind to answer in the language of the topicstarter, or in English please? Thank you.
                      @Mike-4b, your question is answered by @b0hd1, but keep in mind that reducing waypoints will lead to alternate routes. That being said, your question has no relation to the original topic whatsoever and also not to the app, a problem or a bug, so please next time just create a new topic in the correct category, thank you.
                      b0hd1 1 Reply Last reply
                        @Con-Hennekens también valoramos las tuyas. Te animo a seguir trabajando asi de duro!!!
                        • YouTube: @demco17
                        stuart marritt
                        stuart marritt
                        Mike 4b
                        Mike 4b
                          silberfuchs67
                          silberfuchs67
                          210
                          Ed Lauwerens 0
                          Ed Lauwerens 0
                          157
                        • Statement on map spinning
                          hawebo
                          hawebo
                          18
                          25
                          1.7k
                        • New beta! 6.0.0 (514)
                          213
                        • Feature request to change colour of the route-line in My Route Web
                        • Electric Car Travel Mode
