  4. Unable to start a route using remote.
13 Posts 3 Posters 2.8k Views 3 Watching
  • Andre Trudeau
    Andre Trudeau
    Andre Trudeau
    @Corjan-Meijerink, Interesting.. As soon as I enter that screen if I press up it brings me to start. I can go back and forth between start and edit, but as soon as I go further up(waypoints, route settings etc) and come back down to the Start/Edit, the only selectable one is Edit. Got to say pressing up first thing is not very user friendly 😉
      No definitely not!
      The honest answer is that I have no clue yet why that works but just wanted to share that it works 😛
      I'll investigate the issue and work on a fix but at least you now know a workaround.
      • Andre Trudeau
        Andre Trudeau
        Andre Trudeau
        @Corjan-Meijerink ,
        Thank you!
        Still have the App crash on bluetooth keyboard/remote disconnect/connect events btw. I did report this on my existing ticket.
        Cheers!
          I've seen that the ticket too.
          That's even weirder 😉
          • Andre Trudeau
            Andre Trudeau
            Andre Trudeau
            @Corjan-Meijerink ,
            Good 😉 At least I am not crazy.. lol!
            • Andre Trudeau
              Andre Trudeau
              Andre Trudeau
              @Corjan-Meijerink ,
              Discovered something new for the Bluetooth issue...
              The issue does not occur if I have 2 "input" device connected and 1 is disconnected.
              Could you try this to confirm you are seeing the same?
              Cheers!
                Just edited my response. I've seen your ticket but not the actual issue itself 😉
                Not able to reproduce it at all.
                  Both the app crash on connecting controller and this issue should be resolved in the 5.0.1 update. Please let me know when available 😃
                  • Andre Trudeau
                    Andre Trudeau
                    Andre Trudeau
                    Will test and report. Thank you!
                    • Andre Trudeau
                      Andre Trudeau
                      Andre Trudeau
                      Both these issues fix on 5.0.1. Thanks again!
                      Andre Trudeau
                      Andre Trudeau
                        Thomas Schäfer
                        Thomas Schäfer
                      • reuse pictures
