  4. Can't edit favorite in portrait mode
6 Posts 3 Posters 1.5k Views 3 Watching
  • MartinW
    MartinW
    MartinW
    With version 5, I cannot edit a favourite (change name) on my iPhone 12 mini in portrait mode. The input field for the new name appears briefly, but then disappears immediately. But it works fine on an iPhone 11 – the problem is probably related to the display size.
    (It also works on an iPhone 12 mini in landscape mode, but the keyboard covers the input field, so entering the new name is a shot in the dark.)
    • MartinW MartinW
      @Martin-Wilcke Have you set your iOS settings to be zoomed in by default? Wich build do you use? I can reproduce this only when zoomed in and then only in landscape mode:
      MartinW 1 Reply Last reply
        This will be fixed in 5.0.1 update coming this week!
          MartinW
          MartinW
          MartinW
          @Rob-Verhoeff
          IOS 18.7.2
          MRA 5.0.0 - 426
          Standard zoom
          But I don't care about landscape mode, as this is my CP device and I use it in portrait mode only. If this works with 5.0.1, it's all good.
          • MartinW MartinW
            @Rob-Verhoeff
            IOS 18.7.2
            MRA 5.0.0 - 426
            Standard zoom
            @Martin-Wilcke It's fixed as anounced!
            • MartinW
              MartinW
              MartinW
              Yep - can confirm, it’s working now in portrait mode!
              Landscape is still an issue, but that’s caused by the keyboard that covers far too much space. However, as mentioned, I don’t care.
              MartinW
              MartinW
              • Testroute segmenten
                Alderweireld Rudi 0
                Alderweireld Rudi 0
                104
                Hanza 0
                Hanza 0
              • Weather as a service
                Tegel Werner
                Tegel Werner
              • Map Layers
                Don Stauffer
                Don Stauffer
                Andy Smith 5
                Andy Smith 5
