  4. MRA 5.0 426 eigene POI in Karte einblenden
9 Posts 6 Posters 82 Views 3 Watching
    Hallo,
    User haben im GS-Forum das Problem angesprochen, sie würden gerne eigene POI wie im Web Planer auch in der neuen App einblenden können.
    Ich finde es würde noch einmal eine weitere Begeisterung auslösen wenn dieses auch innerhalb der App möglich wäre.
    • POI in App Karte einblenden so wie Favoriten ?
    iPad 9. Gen iOS 26.2 / iPhone 16e iOS 26.2 / iPhone Xr iOS 18.7.3 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
      Fun suggestion for sure!
        Sorry es ist natürlich die V5.0-426 gemeint.
        Question: Will it likely go on a to-do list (if it seems funny)?
          That is a long list already 😉
            Guzzistundefined Offline
            @Corjan-Meijerink no-one said: "development of MyRoute-App would be easy and short job 😁
            May work for Kurviger, Calimoto and other simply tools will be easier 😂 😂 😂
            But please stay with us - we love you.
            • Erik Plaggenborgundefined Offline
              Erik Plaggenborg
              This worked perfectly in the "old" app. While navigating you could see your own POI's Which were turned on in the routelab.
              You can still see them in the new app but not while navigating. So i hope @Corjan-Meijerink can make this work again before next ridingseason. I use those in my work as tour guide to point out POI's and stops to my fellow travelers.
              BMW R1250 GSA Ultimate Edition
              DMD T865 Nav Tab
              Enthousiast MRA/MRA Next gebruiker
              • Erik Plaggenborgundefined Erik Plaggenborg
                @Erik-Plaggenborg said in MRA 5.0 428 eigene POI in Karte einblenden:
                I can see my personal POI while navigating just fine.
                Are you sure you enabled them in the webplanner?
                Turn the "head" (personal) icon into a cross to fix them on the map.
                  Hallo,
                  Nick Carthewundefined Offline
                  @Hubert-Thoring I changed the title of this topic from 428 to 426 to save any confusion.
                    @Con-Hennekens , @Erik-Plaggenborg @Corjan-Meijerink
                    Zur Klarstellung der Problematik:
                    Eigene POI auf dem Startbildschirm der Karte selbst kann man nicht sehen !!
                    • auf dem Startbildschirm unter Suche kann ich keine eigenen POI auswählen, wie es Beispielsweise bei den Favoriten möglich ist, da geht auswählen und dann kann man weiter suchen, das dann auch auf der Karte.
                    • auf dem Startbildschirm kann ich keine eigenen POI unter Suche einblenden Beispielsweise aus einer POI Liste die es ja im Web als Auswahl gibt.
                    Es wäre schön wenn man die eigenen POI über den Startbildschirm unter Suche mit einer Liste auswählen könnte um dann wie die anderen suchen zu können bzw. diese auf der Karte zu sehen.
                    Hinweis:
                    • Beim Navigieren sehe ich meine freigeschalteten POI auf der Karte das ist in der alten und neuen Version so, das ist perfekt so !!
                    Erik Plaggenborg
                    • MRA running on DMD
                      Martin Wilckeundefined
                      Martin Wilcke
                    • Transportmodus
                    • MRA Routeplanner, Zumo XT and a list of waypoints
                    • Distances between waypoints
                      Peter Zehentreiterundefined
                      1.2k
                    • Where can i change the "About" section of my profile on this forum
                      Jan Huismanundefined
                      Jan Huisman
                      1.3k
                    • Nuovo Utente
                      Adrian Avramundefined
