  3. Round-trip generator (rondrit generator) doesn't work from some points
13 Posts 3 Posters 2.4k Views 1 Watching
  • TorqueRider
    You can apparently select/use every avoidance except "Cities".
    When you deselect "Cities" your route will be generated.
    • sudolea sudolea
      Hello,
      I've noticed, while trying out the "rondrit generator" (can I translate this into "roundtrip generator" ?) doesn't seem to work from most starting points that I select in some small village. More specifically, I'm trying to make some roundtrips starting in Krewinkel, a small village in the Belgian Eastern Cantons. I wonder why that can be ?
      Whether I'm selecting my starting point on the road itself, or on crossroads, it all doesn't seem to make a big difference. On the other hand, selecting some bigger village in the neighbourhood doesn't seem to have those problems.
      Is there a logic that I could follow to prevent such difficulties, rather than to try-and-fail ?
      @sudolea
      Did you try the “surprise me “ option from the same location?
      • TorqueRider
        @sudolea said in Round-trip generator (rondrit generator) doesn't work from some points:
        Krewinkel
        Same result but an slightly other notification 🙂
        • sudolea
          sudolea
          sudolea
          Yes, Hans, I did :
          • sudolea sudolea
            Hello,
            @sudolea
            What distance did you add?
            TorqueRider sudolea 2 Replies Last reply
            • sudolea sudolea
              Yes, Hans, I did :
              @sudolea
              I will inform the developmet team, thanks fot sharing.
              sudolea 1 Reply Last reply
                @sudolea
                @Hans-van-de-Ven-MRA-Master
                100, 150 en 200 km.
                  @sudolea
                  sudolea
                  sudolea
                  sudolea
                  @Hans-van-de-Ven-MRA-Master I tried 250 km, and gradually decreased the distance, also entered a duration when distances didn't work. I most frequently set the direction towards the Eifel, Luxemburg, or Germany.
                    @sudolea
                    sudolea
                    sudolea
                    sudolea
                    @Hans-van-de-Ven-MRA-Master OK, top, thank you.
                    For what it's worth : the solution Jack suggests works indeed. However, I think it's suboptimal : I would rather suggest an immediate and intuitive error message when starting a roundtrip from a point of which the software knows that it will result into an "impossible" route. This saves the user from executing the 4 following steps to only at the end be (frustratingly) notified that "there could be found no route". It would also enable a user to let the option to "avoid cities" remain active and select another point right at the start of a roundtrip setup...
                    • TorqueRider TorqueRider
                      100, 150 en 200 km.
                      @Jack-van-Tilburg
                      It didn't work for me, I did a test yesterday
                      sudolea
                      sudolea
                      • Kaart niet zichtbaar
                        212
                      • Xpert overlay not clear
                        Bé Jeuring
                        Bé Jeuring
                        22
                        41
                        367
                        Corrado Miniati 0
                        Corrado Miniati 0
                      • Google maps
                        Ed Bos 0
                        Ed Bos 0
                        208
                      • Trains like Ferries?
                        Corrado Miniati 0
                        Corrado Miniati 0
                        290
