  3. [App] Announcements
  4. Android only update! (4.4.1)
28 Posts 10 Posters 14.2k Views 2 Watching
  • JP d JP d
    @Marinus-van-Deudekom said in Android only update! (4.4.1):
    I would certainly put shapingpoint 7 a bit more in the direction of 8
    Exactly always ensure your waypoints are a good distance from a junction, intersection, roundabout or adjacent road. If you use the (expand) add waypoints option you have to check every single one.
    I've also had MRA take me left onto a single track lane shortcut even though my friend's MRA was showing straight ahead which was the correct way.
    I didn't have (show original route) turned on which would have helped but previously the white line (show original route) didn't follow the road correctly so I turned it off. Looks like it has been fixed now but I'll find out for sure on my trip on the 20th.
    Brian McG Offline
    Brian McG Offline
    @JP-d said in Android only update! (4.4.1):
    not sure if it is the same issue you are refering to but just so you know before your trip there is still an issue with the "original route" line not exactly "following the road" if you are navigating in offline mode
    there are a couple of workarounds, details are here https://forum.myrouteapp.com/post/66551
    JP d 1 Reply Last reply
    • Brian McG Brian McG
      JP d Online
      JP d Online
      JP d
      wrote on last edited by JP d
      #22
      @Brian-McG You're right mate! My mistake I had forgotten to turn WiFi and Data off πŸ€¦πŸ»β€β™‚οΈ.
      I navigate with my old phone (no SIM) using offline maps.
      So you're saying if I open a route offline and then click on the (pen) πŸ–‹οΈ edit route icon, then go to (Menu) scroll down and select (Navigate) the white line original route would follow the blue navigation line correctly?
      Thanks for your reply 🍻
      Brian McG 1 Reply Last reply
      • JP d JP d
        Brian McG Offline
        Brian McG Offline
        @JP-d that sounds about right
        you can test it at home & see the white line not fitting correctly
        I think it is easier to see on longer routes with more points as somewhere MRA are limiting the number of track points for the track calculation, so longer routes deviate away more from the road
        the other work around is start the navigation while your old phone is still connected to the hotel wifi then the white line is calculated correctly as it is online & MRA allows more points for the track caclulation
        then go offline & close the wifi
        • Banshees Offline
          Banshees Offline
          Banshees
          The latest update made the bouton barely distinguished when riding, on Android Auto.
          I know where is the zoom and the POI option (to remove one waypoint while driving). But i can't see correctly the bouton.
          -oOOo-()-oOOo---------------------------------------------
          Banshees
          MRA Gold & Nav - Life
          --------------Oooo-----------------------------------------
          oooO ( )
          _)
          • Banshees Banshees
            Marinus van Deudekom Offline
            @Banshees maybe you can share a screenshot
            • Thomas Neumeyer Offline
              Thomas Neumeyer
              Hi, just out of curiosity. When is the next big update planned? Any teaser available?
              Thomas
              • Thomas Neumeyer Thomas Neumeyer
                Thomas
                Corjan Meijerink Offline
                @Thomas-Neumeyer it’s in beta since yesterday!
                Expected release end of the month.
                  Thomas Neumeyer
                  Cool, thank you Corjan.
                  Banshees
                  Banshees
                  Thomas Neumeyer
                  Thomas Neumeyer
                  JP d
                  JP d
                  ginogino
                  ginogino
                  • It was not possible to find a correct route to Wheels Through Time
                    231
                  • MRA 5.2.2 (489) Route time is calculated incorrectly /// Strecken Zeit wird falsch berechnet
                  • Is there a way to put a Home button in the program
                  • Is there a way to re-order the routes in your routes folder?
                  • How do i export or 'save as' a file into Garmin Camper 770 - Help
                    Bruno 7
                    Bruno 7
                    604
                  • MRA In the BMW - Cradel vertically and horizontally /// MRA im BMW - Cradel senkrecht und waagerecht nutzen
