  4. Traffic situation and road bypasses
14 Posts 4 Posters 5.2k Views 1 Watching
  • Travellexxie
    In your case I would have made a route in Slovenia until the border and in XT set highway "on" and in Italy from the border load a route for Italy and set in XT highway "off".
    Alternativ: make the route in the MRA planner, set highway "on" and make your route (you will have to use a lot of shapingpoints in Italy). Than export the GPX 1.2 and set your recalculation "off". Your route will guide you as you planned it.
    If you, where in my screenshot it says "verkeer", enable traffic, you will see the closed roads. 46687a00-ef54-4c74-813f-c90b97d0e937-image.png
    MRA Lifetime Gold
    Boštjan Kreutz 1 Reply Last reply
    • Travellexxie Travellexxie
      Boštjan Kreutz
      Boštjan Kreutz
      Boštjan Kreutz
      @Lex.Kloet.RX Good idea about creating two separate routes to solve the highway problem.
      About creating one route and using a lot of shaping points... I thought that the max suggested is about 40 shaping/via points, otherwise Garmin would have problems...
      For Garmin XT I also always use GPX 1.1, since that was recomended. GPX 1.2 was said to be for the Zumo XT2 so I never tried it.
      But the most important:
      Well... I have Traffic enabled and I don't see road closed. Check the screen I attached in the OP.
      I do see that the MRA navigated me on the other road, but I don't see that that happened because of the closed road.
      richard 3v Travellexxie 2 Replies Last reply
      • Boštjan Kreutz Boštjan Kreutz
        richard 3v
        richard 3v
        richard 3v
        wrote on last edited by richard 3v
        @Boštjan-Kreutz said in Traffic situation and road bypasses:
        I had a similar issue on Sunday. I was returning from the Eifel area of Germany to the UK via the channel tunnel.
        I took the suggested fastest route using the E40 in Belgium. Three times the motorway was closed with no warning, and worse for me, no suggested diversions.
        OK, the first one I was using offline navigation so that could have been user error, but as I had to stop to figure out my own alternative route I switched my phone onto online, with all traffic settings turned on.
        The next two closures again I got no warnings, and again even worse, no alternative directions.
        This made for a very unpleasant journey as although I had allowed ample time for the suggested route I had to be at the tunnel before a certain time, and these diversions were eating into my safety margin.
        Does anyone have any ideas / suggestions why MRA did not route me around these second two closures.
        • richard 3v richard 3v
          Boštjan Kreutz
          Boštjan Kreutz
          Boštjan Kreutz
          @richard-3v just to be super clear, you were probably using MRA Next on your phone to navigate?
          My case was not while navigating with Next, but while creating route in a MRA route editor.
          • richard 3v
            richard 3v
            richard 3v
            @Boštjan-Kreutz
            Yes, that is correct. Sorry for causing confusion.
            But I would still appreciate an answer from anyone with ideas.
              @Boštjan-Kreutz The XT has 29 viapoints as a maximum for one route (otherwise the route is split). Shapingpoints I don't know by heart, but many more.
              Nope, 1.2 is for all Zumo's. It runs very well on the XT, when you have recalculation off.
              you have to zoom in a little bit more:
              MRA Lifetime Gold
              JP d 1 Reply Last reply
              • Boštjan Kreutz
                Boštjan Kreutz
                Boštjan Kreutz
                Thank you so much for the explanation on max points and also about the export version... I am a new user and these kind of info is always welcome and I will for sure test that out when I get the next chance.
                For the traffic info... I can zoom how much I want, and I don't get the display like yours. I checked to have traffic enabled and also checked all maps (for default I use HERE). I just don't get that red line. On Windows I use Chrome. But I also checked MRA app on my andorid phone, open my test route - still don't see that red line. I also created another new route... no red line... Could it be a location issue?
                • Travellexxie
                  What kind of subscription do you have?
                  MRA Lifetime Gold
                    Boštjan Kreutz
                    Boštjan Kreutz
                    Boštjan Kreutz
                    @Lex.Kloet.RX I have a "MRA Routeplanner Gold Lifetime member", but I don't have NEXT navigation system subscription.
                      @Boštjan-Kreutz try to use the routelab in the app, instead of the MRA Routeplanner 1000034157.jpg
                      MRA Lifetime Gold
                        Boštjan Kreutz
                        Boštjan Kreutz
                        Boštjan Kreutz
                        @Lex.Kloet.RX Interesting.
                        I already did what you suggested yesterday and I attached the screen not showing red line. But I double checked now, on the android MRA app, option website-Routelab -> and now it shows the red line. How? Why?
                        I also tried opening on Windows Chrome browser, the same TestFalzarego route then yesterday, and now I also get red line on the web browser...
                        I guess there was some sort of bug, or something else happened (perhaps some catched files), but I would really like to have this kind of road closures to be shown always and reliable. When I do planing it is really useful not to have to double check another SW or google maps to have crucial information at hand.
                        Anyhow, thanks for all your input. It was nevertheless a good learning experience.
                        • Travellexxie
                          Maybe a cache problem
                          MRA Lifetime Gold
                            JP d
                            JP d
                            JP d
                            @Lex.Kloet.RX said in Traffic situation and road bypasses:
                            200
                            JP d
                            JP d
                            richard 3v
                            richard 3v
                            Boštjan Kreutz
                            Boštjan Kreutz
                              Òscar
                              Òscar
                            • Current city/village name instead of the street name
                              Marten Wiersma
                              Marten Wiersma
                            • 1 post all Bugs & suggestions
                            • Overnight reviews - motorcycle security
                            • Still showing Open Street Map
                            • Trains like Ferries?
                            • Opstarten app in Android.
                              Beemerfrankie
                              Beemerfrankie
                            • Mislukte betaling en opgeheven betaling geeft toch AI!!
