  4. Why is this deviation of the original route already shown when starting the route?
6 Posts 6 Posters 2.0k Views 4 Watching
  • infoevertkuiken.nl Offline
    infoevertkuiken.nl
    Last weekend I drove a route from Zuidlaren to Stroe. And already when starting the route it shows a deviation. Why is that? When driving there the original route could be driven without issues.IMG_6082.PNG
    Brian McG Rob Verhoeff 2 Replies Last reply
    • Adrian Avram Offline
      This post is deleted!
      • nomko Offline
        nomko Offline
        Banned
        Seasonal closure?
        Road works?
        Can you provide us with a link to that specific route please.
        • infoevertkuiken.nl infoevertkuiken.nl
          Brian McG Offline
          Brian McG Offline
          @infoevertkuiken.nl there could be several reasons
          one is that you are navigating online with automatic recalculation enabled,
          when the route has been loaded for navigation it has recalculated the alternative path as being more efficient
          this is possible I think because the route is poorly planned,
          after point 42 it is clear there are multiple paths to get to point 43,
          if a recalculation is done then it is possible any of the other routes could end up being the preferred route
          a simple factor that could change the preferred route could be something like traffic, if you have that enabled
          if you specifically want to follow the white path then at least one other point should have been added between points 42 & 43 to eliminate the possibility of the other paths being calculated
          • Travellexxie Offline
            Berend Botje nog gezien? 😉
            MRA Lifetime Gold
              Rob Verhoeff Online
              Rob Verhoeff Online
              @infoevertkuiken.nl
              Could the option 'fastest' or 'shortest' route in your navigation settings perhaps have an effect? When I try this with one of my own routes, the 'shortest' option under 'Route Optimization' does indeed influence it.
              Heeft de optie "snelste" of "kortste" route in je navigatie instelling wellicht invloed? Als ik dit nl. doe met één van mijn eigen routes, dan heeft de optie "kortste" bij de instelling "Routeoptimalisatie" daar wel invloed op.
              infoevertkuiken.nl
              infoevertkuiken.nl
              • Garmin XT2 - losing my mind!
              • Export to BMW CRN
                700
                3.0k
              • NC500 glitch
              • MRA Beta V6.x - und Beta Webplaner 2.0 vielleicht bald
              • High Contrast Maps
                TuonoPants
                TuonoPants
                1.7k
              • Ability to change units as your navigating
