  3. Via point icons not showing on Zumo XT
24 Posts 3 Posters 7.9k Views 3 Watching
    @Henrik-Müller
    I had the same today🤷‍♂️
    Henrik Müller
    Henrik Müller
    Henrik Müller
    @Hans-van-de-Ven-MRA-Master said in Via point icons not showing on Zumo XT:
    @Henrik-Müller
    Sound "good" - and as your status is instructor, you probably have access to elevate this issue to the right programmer people at MRA ?
    / Henrik
    • Henrik Müller Henrik Müller
      @Henrik-Müller
      / Henrik
      @Henrik-Müller
      I don't know if this is a Garmin or an MRA issue, as I only see this on the XT and not on MRA Navigation. I'm going to test this by putting a route from Garmin Basecamp on my XT.
      Henrik Müller 1 Reply Last reply
        @Henrik-Müller
        Henrik Müller
        Henrik Müller
        Henrik Müller
        If I make a new route on the XT device in trip planner, it works as it should.
        If the problem is in the XT software when importing GPX into trip planner, MRA must report it to the Garmin SW team, as MRA probably have more “weight” in the approach than a bunch of users...?
          @Henrik-Müller
          Then they probably already know at Garmin, and this will be solved with one of the updates
            @Henrik-Müller
            Henrik Müller
            Henrik Müller
            Henrik Müller
            Hi Hans
            I’m writing the route works if you program the route on direct on the XT device in trip planner - so the Garmin own internally route calculation works.
            The issue is starts when I import a ROUTE from MRA into trip planner, then the strange “off road route” between the second last and the last point appears.
            I’m glad you have seen it yourself from MRA - How did your test with Basecamp go ?
            HABVEN aka MrMRA 3 Replies Last reply
              Hi Hans
              @Henrik-Müller
              I have not yet tested with a route from basecamp ...
                Hi Hans
                #19
                @Henrik-Müller
                With a route from BC no problem, given the placement of the next to last route point, it is probably due to the distance between the last and the next to last route point that this will occur.
                I added an extra route point and now the route continues as usual.
                I'm going to test this further.
                I'm going to place this with the developers.
                To be continued.
                  Hi Hans
                  @Henrik-Müller
                  Hi Henrik, the route from the last waypoint to the end point is not calculated correctly, that's why you see either the dotted line of the track or a straight (direct route) route line.
                  It has been reported to the developers, they may need to make a minor adjustment to the .gpx file for the Garmin XT.
                  Thanks for reporting.
                  Henrik Müller 2 Replies Last reply
                    @Henrik-Müller
                    Henrik Müller
                    Henrik Müller
                    Henrik Müller
                    Thanks for your effort - looking forward for this.
                    A little wish, at the export “connector program” it would be nice if the program remember which GPS/ file format you are using, so it’s preselected... 😎
                    A Former User? 1 Reply Last reply
                      A Former User?
                      A Former User?
                      A Former User
                      @Henrik-Müller said in Via point icons not showing on Zumo XT:
                        @Henrik-Müller
                        Henrik Müller
                        Henrik Müller
                        Henrik Müller
                        @Henrik-Müller
                        Have the developers responded, are they also able to reconstruct the scenario?
                          @Henrik-Müller
                          @Henrik-Müller
                          They will work on it.
                          Henrik Müller
                          Henrik Müller
                          A Former User?
                          [[global:former-user]]
                          • Kaart niet zichtbaar
                            212
                            Bé Jeuring
                            Bé Jeuring
                            22
                            41
                            362
                          • Xpert overlay not clear
                            Corrado Miniati 0
                            Corrado Miniati 0
                          • Google maps
                            Ed Bos 0
                            Ed Bos 0
                            208
                          • Trains like Ferries?
                            Corrado Miniati 0
                            Corrado Miniati 0
                            288
