  3. [App] Announcements
  4. New update! (4.4.1)
New update! (4.4.1)
31 Posts 12 Posters 4.0k Views 3 Watching
  • Peter Zehentreiterundefined Offline
    No more access to the forum ( Android App)
    With the new update I can no longer access the forum properly.
    Previously I could see all unread entries at the bottom left, but this option is now only visible in the background but unfortunately cannot be selected.
    BMW R 1250 GS
    BMW Connected Ride Cradle
    Pixel 9 "online"
    SPC Universal mount
    Motorola Edge 40 "offline"
    Sena SLR 3
    Sena 50 R
      That would seem to indicate that you don't have a data connection.
      Peter Zehentreiterundefined 2 Replies Last reply
        @RetiredWingMan The data connection is 100% o.k.
        Both WiFi and data connection via the network operator!
        I can access the forum, I can see the individual sections and can also access them.
        But please take a close look at the screenshot.
        At the bottom left you can see a number in light blue which shows all unread messages in the forum but not selectable.
        The profile picture at the bottom right is also not selectable.
        BMW R 1250 GS
        Pixel 9 "online"
        SPC Universal mount
        Sena SLR 3
        Sena 50 R
          @RetiredWingMan
          I have found the error.
          If you have activated the navigation via the 3 buttons in the gesture control in Android, the error occurs.
          If you switch to gesture control, you can access the unread messages again.
          Would be great if that little issue could be solved
          BMW R 1250 GS
          Pixel 9 "online"
          SPC Universal mount
          Sena SLR 3
          Sena 50 R
          JP dundefined 1 Reply Last reply
            @Peter-Zehentreiter, not really a solution, but a suggestion... 😉
            Go to the forum main page, click your profile avatar, choose settings.
            On that page you can set the default landing page when you enter the forum.
            I have set this to "unread", since basically that is all I look at 😉
            From now on the forum will always open directly to that page.
              Hi Con,
              thanks for your hint.
              It does help with the problem I mentioned (unread messages), but if I then want to go back to previous messages for example, then I have the problem again that the 3-button gesture overlays the forum fields.
              BMW R 1250 GS
              Pixel 9 "online"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
              • Bert 2vundefined Offline
                Bert 2v
                What is the best way to import an GPX actually? I now use Routelab -> Upload
                  @Adrian-Avram great! Happy to read that 🙂
                  Sometimes issues are caused by external factors and then also solved by updating them again!
                  Sorry for the inconvenience you experienced!
                  Manzo91undefined Offline
                  Manzo91
                  wrote on last edited by Manzo91
                  #17
                  @Corjan-Meijerink NOW IT WORKS !!! i've finally upgraded from 4.3.9 to 4.4.1 and all work perfect now. thanks a lot !!!
                  • Manzo91undefined Manzo91
                    @Manzo91 great ! ❤
                    • Bert 2vundefined Bert 2v
                      @Bert-2v just select the GPX file on the phone, click share, select our app 🙂
                        @RetiredWingMan
                        JP dundefined Offline
                        JP d
                        wrote on last edited by JP d
                        #20
                        @Peter-Zehentreiter I have the same problem, see picture. Can't access (show route details) at the bottom of the screen as I use the 3 button navigation and it covers the (show route details). Looks like the MRA team concentrate on gesture navigation. Hopefully they can fix the issue soon.
                          @Corjan-Meijerink said in New update! (4.4.1):
                          Don't worry about it !
                          I just drove a 80km route with 2 stops, everything is working just fine !
                          Resuming navigation every time without any issue, and most importantly no more lagging !!!
                          Hope it also works for all the other users with this issue.
                          Great job !
                          ginoginoundefined Offline
                          ginogino
                          @Adrian-Avram said in New update! (4.4.1):
                          On Android, it's the same as before for me: the request appears to resume browsing and it stays there for hours if you don't press a button:
                          As before if recalculation has been disabled, there are no off-route warnings.
                          Within about 300km yesterday I had a couple of software crashes and had to restart my smartphone, something I had no longer had with the previous app, where can I find the previous app to download.
                            I would suggest trying to remove the app and reinstall it first !
                            Adrian
                            Samsung S24 Ultra and iPhone 13 with Android Auto / CarPlay
                            • Justin Moremanundefined Offline
                              Justin Moreman
                              Can I ask how you update the app. I have looked through but cannot find a software update button?
                                @Adrian-Avram, indeed. But clearing cache and storage (on Android anyways) usually leads to the same result.
                                @Justin-Moreman, the app store of your phone handles that.
                                  #25
                                  Hey, just for your information,
                                  The iPhone XR's battery consumption throughout the day with three apps is perfect, including breaks where the apps weren't turned off.
                                  Charging was done with inductive charging in the cradle...
                                  Info zum Beta Test "Next App" dazu die Hardware ...
                                  iPad 9. Generation iOS 26.10.1 / Handy iPhone Xr iOS 18.7.1 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                                    Hi everyone! 👋
                                    It has been 2 months since the last update. Now that the season is ending it's a nice moment to release a minor update. We are very happy with how the app (and the MyRoute-app platform in general) was a part of a lot of your adventures.
                                    This update will be available in coming days.
                                    Language updates
                                    Thanks to @Chudy and @Krzysztofa our app now supports the Polish language! 🎉 This is only the app, not the website. So if your app is in Polish, the website will probably be English (or whatever you selected).
                                    Android language select
                                    Since day one you could already select a different app language in iOS when accessing the iOS app settings. Now that's possible for Android too! 😏 Especially useful now we have Polish translations.
                                    Note: only Android 13 and higher
                                    iOS GPX import issue
                                    Since an update from iOS the GPX import function of the app was broken 😞
                                    That's fixed again! You can now open any GPX file sent to you with our app again.
                                    Recalculation improvements
                                    Tweaking the recalculation behavior of the app is quite complex due to the vast variety of situations. Over the holiday season we received quite some reports that the app would excessively skip waypoints. In this version we deployed a new version of the waypoint skip algorithm.
                                    Besides that we resolved an issue where sometimes recalculations in track navigation could get stuck.
                                    What's next?
                                    We are working on a major overhaul of the UI / UX of the app. We hope to start beta testing early September and aim for release in October! 🎉
                                    Cheers,
                                    Corjan
                                    wrote last edited by
                                    #26
                                    @Corjan-Meijerink Hello Corjan,
                                    we want to go on another tour in Spain at the beginning of November.
                                    I would be interested to know whether the new update, which is due to be released in about two weeks, will fix the problem with the Silverfox C1 controller?
                                    (The controller only works when the app is set to English.)
                                    I would appreciate your answer.
                                    Best regards
                                    Peter
                                    BMW R 1250 GS
                                    Pixel 9 "online"
                                    SPC Universal mount
                                    Sena SLR 3
                                    Sena 50 R
                                      Best regards
                                      Peter
                                      #27
                                      @Peter-Zehentreiter I don’t expect it to.
                                      In all honesty my perspective of this issue is that it’s Silverfox firmware related. Or at least, the fix needs to originate from them.
                                      We don’t do anything language based regarding these commands. We just receive keyboard commands and apparently in other languages the firmware from SilverFox sends incorrect ones?
                                      Absolutely not pointing fingers but I would not even know where to start in solving the issue.
                                      When using English language setting our app works correctly (as you indicated) because then (apparently) all correct keycodes are sent by the SilverFox firmware.
                                        #28
                                        @Corjan-Meijerink First of all, thank you for your reply.
                                        You're the professional, I'm the layman, so I should believe what you write...
                                        Nevertheless, I find it hard to imagine that the fault lies solely with Silverfox.
                                        The controller worked perfectly at first, but after about two months, the fault suddenly occurred, without any changes being made to the controller but changes were made to the App!
                                        At the beginning of your post, you wrote the following:https://forum.myrouteapp.com/topic/9882/new-update-4.4.1
                                        Since day one, you could already select a different app language in iOS when accessing the iOS app settings. Now that's possible for Android too! 😏 Especially useful now that we have Polish translations.
                                        As a layman, I understand this as follows:
                                        The Android app now also has the option to set the language, which was not possible before, but this feature is only available on Android 13 and higher.
                                        I already mentioned in an email to you that I also have an old Android 12 device and the C1 controller works perfectly on it in German. (There is no option to change the language in the App)
                                        As already mentioned, I'm just the user, but for someone who thinks logically, there must be a connection here.
                                        If the error were exclusive to Silverfox, then the C1 controller should not work at all with the MRA App in German.
                                        How can you explain, that the controller with the identical app version works on Android 12 but not on Android 14/15/16?
                                        I´m curios to read your answer.
                                        BMW R 1250 GS
                                        Pixel 9 "online"
                                        SPC Universal mount
                                        Sena SLR 3
                                        Sena 50 R
                                          #29
                                          @Peter-Zehentreiter, check this website, on your phone, connected with your Silverfox, to see if it sends different keys when set for German or English.
                                          https://jaxeadv.com/barbuttons/keypress-tester/
                                          I find that hard to believe too, unless yo are using some key-mapping app on your phone that interferes with what the Silverfox sends.
                                          JP dundefined
                                          JP d
                                          Thomas Neumeyerundefined
                                          Thomas Neumeyer
                                          ginoginoundefined
                                          ginogino
                                          Justin Moreman
                                          Manzo91undefined
                                          Manzo91
                                          Bert 2vundefined
                                          Bert 2v
                                          • twee routes tegelijkertijd
                                          • V5.0.0 (418) - CarPlay Autozoom and Camera View
                                            Dave J 0undefined
                                          • Update 5.0 - Updated beta version
                                            M. Schrijverundefined
                                            150
                                          • Avoid Highways when rout is loaded
                                          • Android auto problem
                                            D Griffinundefined
                                            D Griffin
                                            688
                                          • As I would like
                                            Aiello antoninoundefined
                                          • Creating and populating Events should be renewed too!
                                          • Question about membership
