  3. [App] Announcements
  4. New update! (4.4.1)
New update! (4.4.1)
31 Posts 12 Posters 11.8k Views 3 Watching
    @Adrian-Avram @Thomas-Neumeyer We updated some engines that hopefully resolve the issue - curious to hear your feedback.
    Adrian Avramundefined Offline
    @Corjan-Meijerink no more lagging after update, all menus are snappy when opening. I will drive from work to home in 1 hour and test also the navigation.
    Thanks !
    Adrian
    Samsung S25 Ultra and iPhone 13 with Android Auto / CarPlay
      Thanks !
      @Adrian-Avram great! Happy to read that ๐Ÿ™‚
      Sometimes issues are caused by external factors and then also solved by updating them again!
      Sorry for the inconvenience you experienced!
      Adrian Avramundefined Manzo91undefined 2 Replies Last reply
        @Corjan-Meijerink said in New update! (4.4.1):
        Don't worry about it !
        I just drove a 80km route with 2 stops, everything is working just fine !
        Resuming navigation every time without any issue, and most importantly no more lagging !!!
        Hope it also works for all the other users with this issue.
        Great job !
        Adrian
        ginoginoundefined 1 Reply Last reply
        • Thomas Neumeyerundefined Offline
          Thomas Neumeyer
          Hello, no joy here. In portrait mode it is laggy when the next street name is moving because of its length in the "instruction" window. When in landscape and the street name is stationary it is not laggy. Regards Thomas
          • Peter Zehentreiterundefined Online
            No more access to the forum ( Android App)
            With the new update I can no longer access the forum properly.
            Previously I could see all unread entries at the bottom left, but this option is now only visible in the background but unfortunately cannot be selected.
            BMW R 1250 GS
            BMW Connected Ride Cradle
            Pixel 9 "online"
            SPC Universal mount
            Motorola Edge 40 "offline"
            Sena SLR 3
            Sena 50 R
              That would seem to indicate that you don't have a data connection.
              Peter Zehentreiterundefined 2 Replies Last reply
                @RetiredWingMan The data connection is 100% o.k.
                Both WiFi and data connection via the network operator!
                I can access the forum, I can see the individual sections and can also access them.
                But please take a close look at the screenshot.
                At the bottom left you can see a number in light blue which shows all unread messages in the forum but not selectable.
                The profile picture at the bottom right is also not selectable.
                BMW R 1250 GS
                Pixel 9 "online"
                SPC Universal mount
                Sena SLR 3
                Sena 50 R
                  @RetiredWingMan
                  I have found the error.
                  If you have activated the navigation via the 3 buttons in the gesture control in Android, the error occurs.
                  If you switch to gesture control, you can access the unread messages again.
                  Would be great if that little issue could be solved
                  BMW R 1250 GS
                  Pixel 9 "online"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                  JP dundefined 1 Reply Last reply
                    @Peter-Zehentreiter, not really a solution, but a suggestion... ๐Ÿ˜‰
                    Go to the forum main page, click your profile avatar, choose settings.
                    On that page you can set the default landing page when you enter the forum.
                    I have set this to "unread", since basically that is all I look at ๐Ÿ˜‰
                    From now on the forum will always open directly to that page.
                      Hi Con,
                      thanks for your hint.
                      It does help with the problem I mentioned (unread messages), but if I then want to go back to previous messages for example, then I have the problem again that the 3-button gesture overlays the forum fields.
                      BMW R 1250 GS
                      Pixel 9 "online"
                      SPC Universal mount
                      Sena SLR 3
                      Sena 50 R
                      • Bert 2vundefined Offline
                        Bert 2v
                        What is the best way to import an GPX actually? I now use Routelab -> Upload
                          Manzo91undefined Offline
                          Manzo91
                          wrote on last edited by Manzo91
                          #17
                          @Corjan-Meijerink NOW IT WORKS !!! i've finally upgraded from 4.3.9 to 4.4.1 and all work perfect now. thanks a lot !!!
                          • Manzo91undefined Manzo91
                            @Manzo91 great ! โค
                            • Bert 2vundefined Bert 2v
                              @Bert-2v just select the GPX file on the phone, click share, select our app ๐Ÿ™‚
                                @RetiredWingMan
                                JP dundefined Offline
                                JP d
                                wrote on last edited by JP d
                                #20
                                @Peter-Zehentreiter I have the same problem, see picture. Can't access (show route details) at the bottom of the screen as I use the 3 button navigation and it covers the (show route details). Looks like the MRA team concentrate on gesture navigation. Hopefully they can fix the issue soon.
                                  Great job !
                                  ginoginoundefined Offline
                                  ginogino
                                  @Adrian-Avram said in New update! (4.4.1):
                                  On Android, it's the same as before for me: the request appears to resume browsing and it stays there for hours if you don't press a button:
                                  As before if recalculation has been disabled, there are no off-route warnings.
                                  Within about 300km yesterday I had a couple of software crashes and had to restart my smartphone, something I had no longer had with the previous app, where can I find the previous app to download.
                                    I would suggest trying to remove the app and reinstall it first !
                                    Adrian
                                    • Justin Moremanundefined Offline
                                      Justin Moreman
                                      Can I ask how you update the app. I have looked through but cannot find a software update button?
                                        @Adrian-Avram, indeed. But clearing cache and storage (on Android anyways) usually leads to the same result.
                                        @Justin-Moreman, the app store of your phone handles that.
                                          #25
                                          Hey, just for your information,
                                          The iPhone XR's battery consumption throughout the day with three apps is perfect, including breaks where the apps weren't turned off.
                                          Charging was done with inductive charging in the cradle...
                                          iPad 9. Gen iOS 26.3.1 / iPhone 16e iOS 26.3.1/ iPhone Xr iOS 18.7.6 / PC mit MS Win11 /โ—๏ธMyRoute-App im Cradel und Remotek-Oneโ—๏ธ Info zu MRA & Remotek One
                                          Thomas Neumeyer
                                          ginoginoundefined
                                          ginogino
                                          JP dundefined
                                          JP d
                                          Manzo91undefined
                                          Manzo91
                                          Justin Moreman
                                          Bert 2vundefined
                                          Bert 2v
                                          • route overbrengen naar BMW Navigator 5
                                            white.mouseundefined
                                          • vraagje over route uit bibliotheek
                                            1.9k
                                          • ik zoek het goede adres bij soesterberg entree 4 van park vliegbasis
                                            Ralph Janssenundefined
                                            Ralph Janssen
                                          • Zoom functie in carplay werkt niet ondanks goede settings
                                          • XT3 File Transfer
                                            David Ficklingundefined
                                            David Fickling
                                          • Multiple users to edit route
                                            Martin Garandundefined
                                            Martin Garand
                                            3.0k
                                          • Start route bij dichtstbijzijnde routepunt werkt niet
