  4. Which map layer do you recommend when navigating??
3 Posts 3 Posters 1.3k Views 2 Watching
  • Johannes Bergmark
    Johannes Bergmark
    Johannes Bergmark
    Hello!
    I have mainly used OSM, but there are other alternatives such as TomTom, Here etc..
    I do navigate with the MRA on my Android device fitted on the motorcycle, I wonder if there is any benefits to use either of the layers. I guess maybe it is only important to use i.e. TomTom if you would normally extract the route such a device. Is there any benefits to use OSM versus Here?
    Also, I guess you may select which map layer to use when constructing a route, is there any benefits to chose the layers against each ither?
    In two weeks we will travel south along Europe.
    Brian McG 1 Reply Last reply
    • RainerT
      RainerT
      RainerT
      have you read the dokumentation already?
      • Johannes Bergmark Johannes Bergmark
        Hello!
        Hi @Johannes-Bergmark if you are explicitly asking about the map layer in the navigation app (the green arrow)
        As far as I understand it makes no difference to the navigation which map layer you use
        The map layers in the navigation app are purely a graphic layer so you pick the one that most pleases you
        I also tend to use the OSM as it has more contrasting colours & I find it easier to read,
        the Here map is just a bland indecipherable grey mush
        RainerT
        RainerT
        Johannes Bergmark
        Johannes Bergmark
        • MRA Studio export speed
        • route bug
        • Map colours and side roads
        • Hiya from UK
          Russ Nattrass 1
          Russ Nattrass 1
        • geeft routepunt niet weer
