  4. Voice prompts issues
11 Posts 7 Posters 2.8k Views 3 Watching
  • Ed Van Aukenundefined Offline
    Ed Van Auken
    Navigation app when giving voice prompts starts in middle cutting off the initial information. This just started yesterday 7 August 2025.
    I am using android s24. Running mra version 4.4.0-404.
    I have tried rebooting app, and phone as well as different speed on the tts settings. No change.
    Ed
    • Ed Van Aukenundefined Ed Van Auken
      Ed
      Rob Verhoeffundefined Offline
      @Ed-Van-Auken Under what kind of circumstances does this happen? An A–B route, a roundtrip or a self-made route with waypoints? In the latter case, the cause of the less effective voice guidance may be that your waypoint is placed too close to a junction or right on top of a roundabout.
      • RainerTundefined Offline
        RainerT
        Simply share the route.
        Sometimes the BT-Connection to your helmet is laggy, especially in case you have another sound source (music) active.
        RT
          Ed Van Auken
          I have been using it this week to get around the town I was visiting. Mainly as A-B route.
            @Ed-Van-Auken Then I also start thinking more about a BT connection that isn’t optimal. Possibly poor GPS reception?
              It can be software (MRA) related. But you are the first to mention this and the last update is already from a while ago. So the chance it is MRA related is small.
              Most likely your headset itself or the combination phone and headset.
              Are you using other software like i.e Spotify together with MRA. Maybe even Samsung Soundassistant?
              • F Nickundefined Offline
                F Nick
                I often have the same issue . Can’t work out the cause . Annoying as hell!
                  I have had the same issue as well. I think it is caused by my Sync3 AA/CP headend. I have not heard it with my direct connected helmet headset.
                  • Graemeundefined Offline
                    Graeme
                    Hi have the same issue, on Android auto devices on the bike and in the car, you miss the first bit of the announcement, e.g. at a turn that's 400 yards away, you just year "hundred yards turn left". Can the start of the announcement be padded to make the connection to the Bluetooth device happen prior to the announcement?
                    • Graemeundefined Graeme
                      @Graeme, indeed, and probably no coincidence: the time it takes for the audio duck (the lowered music volume) to be restored takes a long time. Probably the time needed for those lost syllables...
                        I have not noticed this on my Android Auto setup. The instructions were always complete not a part of it.
                        I've not yet used 4.4.0/4.4.1.
                        RainerTundefined
                        RainerT
                        F Nickundefined
                        F Nick
                        Ed Van Auken
                        Graemeundefined
                        Graeme
                          AWDC LAOundefined
                          273
                        • Tracklog fails
                          Edwin_Mundefined
                          Edwin_M
                        • Weg is niet te berijden in Google maps wel
                          AWDC LAOundefined
                        • Routepunten
                        • Is there a trial period for the app?
                        • Default Map Layer in Animate
                        • MRA Shop für Merchandise geschlossen ?
                          Lenny Oundefined
                          Lenny O
