  4. Indicator arrow drifts all over the map.
26 Posts 13 Posters 11.6k Views 4 Watching
    Most scenic route tunnels don't have fallback for GPS and cellphone.
    Tunnels are normally known on the maps. And it is known GPS signal is gone in tunnels. So the software must take over. Every software has it own way of doing this. Mostly the software expects you drive at a constant speed through a tunnel and after leaving the tunnel (according to the map) they stay on this course for a while. In the mean time, the software tries to find the GPS signal again and links to the GPS again for a more accurate postion.
    • Bouke Ent
      Now back and had no drifting arrow. as said before i had an arrow that in 25% of the time was behind. i did test today on other app and no problems. if it was behind i had to restart the app.
      i use offline and no recalculation.
      an other thing that seems not to work is starting a track in offline mode.
      • Travellexxie
        I have the same problems with the "arrow behind" case. Well not only arrow but also the navigation itself.
        "In 400 meters turn right", a split second later "turn right now"...
        MRA Lifetime Gold
        Bouke Ent 1 Reply Last reply
        • Travellexxie Travellexxie
          @Lex.Kloet.RX said in Indicator arrow drifts all over the map.:
          when it is behind i get message on the crossing so to late. but as i said it is not always behind. also i have no other gps apps running and also no tracking.
            This lagging is also visible in the tracklog. Less trackpoints and thus more straight lines.
            • Bouke Ent
              #26
              just go replay from support. it can be that driving navigate route as track is giving problems when it is behind. there advice is to use only route if this happens and look if it then is ok. i will try that. for me this options saves a lot of time to make route precise on here map. but if this works it is for me ok.
              RainerT
              RainerT
              ErikMatthezing
              ErikMatthezing
              Thomas Neumeyer
              Thomas Neumeyer
              D Griffin
              D Griffin
              Patrick Kelley
              Patrick Kelley
              Luk4s7
              Luk4s7
              Ralph Kafka
              Ralph Kafka
                guenniguenzelsen
                guenniguenzelsen
                TomOnTour
                TomOnTour
              • de connector app Windows
              • vrienden toevoegen
              • [TIP] Oplossing voor wegvallende verbinding (Android Auto / CarPlay) & dubbele lijnen in MyRoute-app op Carpuride
              • Nieuwe route delen met oude versie rijden
              • Are all HERE maps dark-themed?
