  4. SilverFox C1 button not working in MRA
24 Posts 5 Posters 8.6k Views 3 Watching
    So disabling that Android setting was the fix? Now it works as expected?
    @Corjan-Meijerink The Button App is needed, for example, using Google Maps in F1 mode. When I have the Button App installed, MRA generally works incorrectly.
    Riku knows this and referred me to the DMD forum...but unfortunately, no one there answers...Riku himself contacted the DMD forum, and Joao told him he'd like to look into the topic sometime...that was about two months ago.
    I don't have the Button App installed anymore, and as I said, everything works (only zooming out doesn't work).
    BMW R 1250 GS
    DMD-NOR7E 7"
    SPC Universal mount
    Motorola Edge 40 "offline"
    Sena SLR 3
    Sena 50 R
    • Arjan de Vries
      Arjan de Vries
      Arjan de Vries
      If you contact SIlverfox you can get the latest firmware which is still in testing fase. I did that and everything works.
        @Arjan-de-Vries Firmware update 1.2 already done, I even received a replacement unit from SilverFox. Unfortunately, zooming out is still not possible.
        BMW R 1250 GS
        DMD-NOR7E 7"
        SPC Universal mount
        Sena SLR 3
        Sena 50 R
          @Peter-Zehentreiter last week I received update 1.6 from Riku
          Peter Zehentreiter Arjan de Vries 2 Replies Last reply
            @Marinus-van-Deudekom I find it hard to believe the problem is with the C1 controller. Riku thoroughly tested the replacement device for functionality before sending it to me. The controller works even when I use other apps with it.
            Only zooming out in MRA doesn't work.
            Centering the map, switching to different modes, skipping waypoints, zooming in, everything works. Moving the map... all without problems. As already mentioned... I've created a ticket and hope Corjan will find the error.
            BMW R 1250 GS
            DMD-NOR7E 7"
            SPC Universal mount
            Sena SLR 3
            Sena 50 R
              Arjan de Vries
              Arjan de Vries
              Arjan de Vries
              @Marinus-van-Deudekom said in SilverFox C1 button not working in MRA:
              What does the 1.6 do instead of the 1.2?
              • Arjan de Vries
                Arjan de Vries
                Arjan de Vries
                C1 has 1.2 update
                H1 has 1.6
                  C1 has 1.2 update
                  H1 has 1.6
                  @Arjan-de-Vries in the readme 1.6 said it was suitable for all Silverfox remotes
                  Arjan de Vries 1 Reply Last reply
                    Arjan de Vries
                    Arjan de Vries
                    Arjan de Vries
                    I asked Riku from silverfox. He told me this.
                      @Arjan-de-Vries Riku knows best💪
                      • Makro
                        Makro
                        Makro
                        I have been in contact with SilverFox. I described the issue. They are aware of it.
                        It is something to do with the Buttons app, unfortunately. It is developed and administered by DMD/Thork Racing, but SilverFox are in the early stages of developing their own app.
                        So, for now I will have to decide if I want the controller to be Waze/Maps or MRA compatible, before I start riding.
                        Best regards, Makro
                        • Makro Makro
                          Arjan de Vries
                          Arjan de Vries
                          Arjan de Vries
                          @Makro said in SilverFox C1 button not working in MRA:
                          What do you do before riding?
                          I have the T865X and the C1. It disconnects every time i turn of the engine. After starting again, the connection will not happen. I have to remove the C1 through the settings en reconnect again. Any ideas?
                          Makro 1 Reply Last reply
                            Makro
                            Makro
                            Makro
                            @Arjan-de-Vries said in SilverFox C1 button not working in MRA:
                            You have another setup than I do. Your Silverfox is wired to your tablet for both power and data, while mine uses Bluetooth to my tablet for data. Apparantly that changes how things work.
                            Best regards, Makro
                            • Arjan de Vries
                              Arjan de Vries
                              Arjan de Vries
                              What is your setup??
                              Arjan de Vries
                              Arjan de Vries
                              Makro
                              Makro
                              • F014 WP Numbering illogical
                              • Map colours and side roads
                              • GPX POI Editor
                                RainerT
                                RainerT
                              • OSM Routing with MRA
                              • F013 Facilities/POIs – A search function covering the entire map is unfortunately missing here.
                              • Route MRA importeren in Google Maps
                              • F016 Colors only change after leaving the planning
