  4. Android Auto bugs and improvements
20 Posts 7 Posters 7.8k Views 2 Watching
  • Banshees Banshees
    Your picture Not look like MRA to me... or i don't have the same info on mine !
    Here what i can see if i look at MRA on my Google Android Auto (when i activate the record) :
    The record option (follow) not seem to exist on the Android Auto version of MRA :
    • I then need to access my Phone (that i usually keep in my TourPack.. with the 12v charging module there), and hit the red incone.
    • Once activate, i can drive.. but i only see the map mooving.
    Having the "Actual Speed" and "maximum speed on that road) help as :
    • Some car / motorcycle maker not show the real speed.. so the GPS (MRA) is more accurate.. approx 5 km/hm difference in most cases
    • When you drive in small road (not highway), sometime the speed sign are partially hidded by tree ... so having them on the screen help.
    When i plan my drive, and select it.. then those info are on the screen.
    So : if i plan a drive, or use the Follow (record) option, having the same info displayed on the screen will be usefull !
    @Banshees My picture shows my speedometer on my Triumph Tiger, it shows my speed!
    • Banshees
      Banshees
      Banshees
      Your Triumph yes, like any motorcycle, show a speed based on the speedometer of the bike. Unless your motorcycle show a different and more accurate speed then most North American (canada) motorcycle brand / model?
      My 2024 Harley-Davidson is Analog speedometer (i choose that model because of this old analog look) .
      And as i tell in my previous comments, most North American (canada) car and motorcycle not showing the real speed... , and i heard that there is a law in EU that tell car maker to adjust the speed shown on the speedometer 5-10% lower, so i supposed the same rules apply here, as i found out it is 5km off for most vehicle i tested at 100km/hrs (show 95 on the car, but 100 on the gps)
      So when i drive, same for fiew of my friends, we look at the GPS software as it is a more reliable speed information...or more because we can run legally faster...
      The 2 Most well know GPS software used by car driver in canada show on their Widget the actual speed calculate by GPS, and also show known maximum speed allowed on the road.
      So it's the reason i comment here, that the 2 widget information not appear in following mode (or record mode), compare to the mode when we open a plan ride.
      -oOOo-()-oOOo---------------------------------------------
      Banshees
      MRA Gold & Nav - Life
      --------------Oooo-----------------------------------------
      oooO ( )
      _)
      • Banshees Banshees
        @Banshees My photo of my speedometer was a tongue in cheek comment, it was meant as a humorous reply.
        “Tongue-in-cheek" refers to something said or done in a humorous, ironic, or even sarcastic way, often with a hint of insincerity. It means the statement isn't meant to be taken seriously or literally. The expression implies a playful or whimsical exaggeration, rather than genuine seriousness.
        A free ride mode where speed is shown without following a route has been asked for on numerous occasions and the answer from the developers is always the same. It will be added but not until the work to improve stability and battery consumption is complete.
        Banshees 1 Reply Last reply
        • OGRIII
          OGRIII
          OGRIII
          Ok I was about to give you a glowing reference that at long last the app was working well with Android Auto and that I was also now able to get the male United Kingdom voice working. However, the big BUT, the software freezes if part way round a ride one decides to stop for a break. So engine switched off and phone unplugged from Android. After the break plug the phone back into android auto switch on engine let android auto screen fire up click on the mra icon on the android auto screen, map shows ok. However on moving off the direction arrow freezes and does not move. I am using expensive cables on both my Honda NT 1100 and similar expensive cables in my Honda Civic Prelude Mk10. This seizure of the software happens on both vehicles under the same conditions. On the car I unplugged the cable from my samsung A52 mobile phone and replugged it in and managed to kick start the software. On the motorcycle tried the same trick without success. All my software on phone and MRA is up to date. This problem does not occur using TomTom Go software or Google maps. Will you please therefore provide a permanent fix to overcome this problem, which is not unique to me only, judging by the various similar comments on this forum. Once this frustration is fixed then the rest of the navigation works well. I am a university professor covering all STEM and CAD subjects to MSc and beyond. I am 80 years of age and am one of your longest users from the very early days when Michael first started up. I have been very patient waiting for the Navigation App to work correctly with Android Auto since you first started to develop it. Before I decide that enough is enough, please fix this problem soonest before I am forced to comment negatively to my vast number of motorcycle followers in UK and advise them to try other navigation and routing programmes that work satisfactorily. I await your positive proactive reply to my concerns.
          Nick Carthew Marinus van Deudekom 2 Replies Last reply
          -3
          • OGRIII OGRIII
            @OGRIII You had my full attention up to the point where you threatened bad publicity!
            Do you honestly think that MRA enjoy having an unhappy customer?
            How is your threat going to speed up the process of assisting you?
            If you’ve been a customer for all this time, you will be aware that MRA is not a multimillion dollar company, so resources have to be used wisely.
            Finding a fix for the battery consumption problem has taken a lot of those precious resources.
            • OGRIII OGRIII
              @OGRIII you must have seen that the use of Android Auto is a chance for you to get trouble. Depending on the combination of the phone and the AA device, some have a lot of trouble like yourself and some have almost none, like myself. The limitations of AA was the recasons for me not to have a second screen on my bike but getting a rugged real device for the bike. Thus I have no problems on the bike and since I use the AA system only in the car to do some testing I don’t exoeriance the trouble you’re having. MY conclusion is that the combination I’m using gives me no trouble and for thé fun rides with the bike I use the T865X.
              I know that the team is working their asses Off to fix all problems and I would hope that a wise person like yourself would give them more credit. A compliment works better to get things done
                That is indeed still an issue we are actively investigating / attempting to fix.
                Main issue is that all our test setups never show this issue and the logs do not indicate where the issue could be.
                There is absolutely no need to pressure us, it's not like we actively enjoy introducing issues and we always attempt to fix it. No need for others to comment on this specific subject.
                  Banshees
                  Banshees
                  Banshees
                  @Nick-Carthew you just show me an expression i didn't know 😁
                  My native language is French, and my English skills is more technical... So the thong expression is new for me 😁😜
                  Meanwhile... I still enjoy this application, i will convert my wife to the same package!
                  I'm in camping now, so having multiple option of map sources is Awsome!
                  Banshees
                  oooO ( )
                  _)
                  • Banshees Banshees
                    @Banshees, Are you referring to @Nick-Carthew his "Thong-in-cheek" comment? I thought I read something different, and I hope for him I read right... 🤣
                      @Con-Hennekens 😁
                      OGRIII
                      OGRIII
                      Banshees
                      Banshees
                      bluetuz
                      bluetuz
                      • Testroute segmenten
                        Alderweireld Rudi 0
                        Alderweireld Rudi 0
                        105
                        Hanza 0
                        Hanza 0
                      • Weather as a service
                        Tegel Werner
                        Tegel Werner
                        Andy Smith 5
                        Andy Smith 5
                      • Lane view in Android Auto
                        denWINNE
                        denWINNE
