Scenic routing & RouteXpert library improvements
Nice, but I ran into an issue, unable to create a roundtour in curvy and very curvy
@Edwin_M please try again
Throughout the day we kept making some changes. -
Throughout the day we kept making some changes.@Corjan-Meijerink just now (in house at front near road) finish at the back (brandgang) wasn't able to get a route at the garden, so tried to.move to the front to see if that would change something.. But later I saw that finish stays at the back
Fantastisch. Eerst kwam de GPS shop uit Notter met de motorkaart voor de Garmin, speciaal voor motorrijders. En nu komen jullie met iets soortgelijks. Echt vergelijkbaar. Dit maakt alles nog weer mooier!
Fantastic. First came the GPS shop from Notter with the motorcycle map for the Garmin, especially for motorcyclists. And now you come up with something similar. Really similar. This makes everything even more beautiful!
When I finally got it going.. It came up with route 4 times longer then requested
@Edwin_M said in Scenic routing & RouteXpert library improvements:
Daar moeten de dev's zeker nog wat tweaken. Ze hebben deze al in het vizier.
That definitely still needs to be — and is being — tweaked by the devs!
Trying to do a scenic route from my home to a location all I get is this?
Indeed fixed the big OSM issue. Unfortunately the new higher quality route generation has been undone for now. Back up soon again! But the big fire has been extinguished
They have been depricated / automated. Thereby the route generator automatically takes into consideration roads that have been used by RX routes. I am not sure if the new Scenic roads layer is also incorporated, but I think yes.
Rob Verhoeff referenced this topic on
