  3. [Web] Announcements
  4. Scenic routing & RouteXpert library improvements
Scheduled Pinned Locked Moved [Web] Announcements
32 Posts 18 Posters 27.3k Views 8 Watching
  • Edwin_M
    Edwin_M
    Edwin_M
    Update!! Het werkt nu.
    Zojuist de nieuwe Beta en nu werkt het prima
      Fantastisch. Eerst kwam de GPS shop uit Notter met de motorkaart voor de Garmin, speciaal voor motorrijders. En nu komen jullie met iets soortgelijks. Echt vergelijkbaar. Dit maakt alles nog weer mooier!
      Fantastic. First came the GPS shop from Notter with the motorcycle map for the Garmin, especially for motorcyclists. And now you come up with something similar. Really similar. This makes everything even more beautiful!
      • Edwin_M
        Edwin_M
        Edwin_M
        Te vroeg gejuichd, stap op motor. Klik rondrit. Weer zelfde meldingen. Geforceerd afsluiten en opnieuw, geen verschil
        • Edwin_M
          Edwin_M
          Edwin_M
          #24
          When I finally got it going.. It came up with route 4 times longer then requested
          • Edwin_M Edwin_M
            @Edwin_M said in Scenic routing & RouteXpert library improvements:
            Daar moeten de dev's zeker nog wat tweaken. Ze hebben deze al in het vizier.
            That definitely still needs to be — and is being — tweaked by the devs!
            • stuart marritt
              stuart marritt
              stuart marritt
              Trying to do a scenic route from my home to a location all I get is this?
              • AWDC LAO
                BRAVO !
                • Edwin_M
                  Edwin_M
                  Edwin_M
                  I did a few tests just now. Works a lot better. Distance ok and speed of generation was much faster
                    Indeed fixed the big OSM issue. Unfortunately the new higher quality route generation has been undone for now. Back up soon again! But the big fire has been extinguished 🙂
                    • Bouke Ent
                      This post is deleted!
                      • iggs58
                        iggs58
                        iggs58
                        What has happened to the twisty vs winding and high altitude vs low altitude options?
                          They have been depricated / automated. Thereby the route generator automatically takes into consideration roads that have been used by RX routes. I am not sure if the new Scenic roads layer is also incorporated, but I think yes.
                          • Rob Verhoeff Rob Verhoeff referenced this topic on
                          Stanisław
                          Stanisław
                          Edwin_M
                          Edwin_M
                          stuart marritt
                          stuart marritt
                          Albert van den Elsen
                          Tony 13
                          Tony 13
                          iggs58
                          iggs58
                          MarcM
                          MarcM
                          Ralph c
                          Ralph c
                          James Lewington
                          James Lewington
                            guenniguenzelsen
                            guenniguenzelsen
                            804
                            Grant de-St-Croix 1 0
                          • Trips in Commercial Clubs?
                            Mike West
                            Mike West
                          • Exporting GPX
                            smfollen 0
                            smfollen 0
                          • Na rit vanuit event geen tracklog
                            Hanza 0
                            Hanza 0
                          • Storage of tracklogs
                          • wowwwwwwww
