  3. [Web] Announcements
  4. Scenic routing & RouteXpert library improvements
Scheduled Pinned Locked Moved [Web] Announcements
32 Posts 18 Posters 25.6k Views 8 Watching
    Hi everyone! 👋
    Quite a while back (April), we released a new version of our scenic routing algorithm. Unfortunately due to some issues we had to revert that release and go back to the drawing board. Today, is the day that everything will work as expected! 🎉
    The website has been update with 3 very major improvements.
    Scenic routing / roundtrips
    At MRA we have quite a lot of interesting route data. Due to the hard work of our RouteXperts, we know where you should be driving. Besides that, we also have an external dataset that indicate thrilling roads. Why not use this data to improve our routing algorithm? This was the idea that we worked on for the past months 😏
    When you now generate a scenic route or roundtrip, the quality of it will be a lot better than before. As we use those roads to identify where your route should go. Besides that, we modify the route a bit to remove unwanted u turns in the middle of a street.
    Besides that, we also improve the user experience of the scenic route / roundtrip generator on the website. Not much has changed regarding functionality, you just need to click way less 🙂
    Are you using the app? No update required! Improve routing is available immediately too! 🎉
    RouteXpert library
    Who uses the RouteXpert library? Quite a lot of people actually do but this can always be more! The content in the library is simply amazing.
    The biggest issue with the library is that you simply cannot actually easily find the routes you are looking for. When moving around the map, you'd see the start of all routes but not actually what route it is / how it flows. All those issues are of the past! 😃
    When you open the library as of today, you immediately see the routes on the map. You don't need to scroll down to get the preview. Even better, the routes shown match the ones that are visible on your map 💥
    Zoom in more and you see exactly what routes you can choose from.
    By making these changes to the RouteXpert library it has become way more fun to find the routes you want to drive. Another minor change is that we've modified the filters to be a bit more realistic to what is used.
    Did you know that you can now hover on the icon in the RouteXpert library to get a quick preview too? 😃
    A extremely nice result of these changes are also that the library has become more useful for everyone around the world! Getting suggestions for popular routes in The Netherlands when you are in the UK is simply stupid.
    Custom overlays
    Now you might be one of those users who says "I want to do everything myself". We respect those a lot as we are quite alike 😉
    For you, we've added 2 new overlays! The MRA RouteXperts overlay and the MRA Scenic overlay.
    The first one displays all the RouteXpert used roads. You might want to use those roads too.
    The second one displays roads from a custom data set that should be thrilling to drive.
    As you can see, the RouteXperts traveled almost every road in The Netherlands whereas not a lot of thrilling roads can be found. Why don't you try out these overlays in your own area? 😃
    Note: the zoom levels at which these overlays can be used is slightly restricted.
    Summary
    With these changes we hope to elevate route generation to a new level and make finding the best routes and roads even easier!
    Cheers,
    Corjan
    @Corjan-Meijerink incredible update again from the dev-team. The best is simply getting better and better... 🤩
      @Stanisław, You need to zoom in a bit further 😉
      Stanisław
      Stanisław
      Stanisław
      @Con-Hennekens I can see now, thanks. My suggestion is that it could stay marked while changing zoom, now have to mark each time I am zooming in. Very nice feature as I am just planning my trip to Spain for this Fall 🙂
      Staszek
        I just noticed that issue too, will be fixed soon!
        • MarcM
          MarcM
          MarcM
          wrote on last edited by MarcM
          @Corjan-Meijerink Nice nice nice, Question: When I make route from A to B (in the Alps) and when I click on "Routes Nearby", I have to open route by route, it would be very nice if I can see the same as when I open the Bib ...
          • Bart De Medts
            Nice Job @Corjan-Meijerink
            • Albert van den Elsen
              Thank you Corjan and your team. Nice work
              iPhone 15,
              Carpuride W702 Pro
              Sena 20S EVO headset
              Harley Davidson Road King M8
              • James Lewington
                James Lewington
                James Lewington
                Great work, looking forward to using this on my next ride!
                  Just saw the update in the planner and wondered how about! But the explenation is good! And Fortunately, the two options have different colours.
                  Good job done!
                  • Edwin_M
                    Edwin_M
                    Edwin_M
                    Nice, but I ran into an issue, unable to create a roundtour in curvy and very curvy
                    • Edwin_M Edwin_M
                      @Edwin_M please try again 🙂 Throughout the day we kept making some changes.
                      Edwin_M 1 Reply Last reply
                        Edwin_M
                        Edwin_M
                        Edwin_M
                        #17
                        @Corjan-Meijerink just now (in house at front near road) finish at the back (brandgang) wasn't able to get a route at the garden, so tried to.move to the front to see if that would change something.. But later I saw that finish stays at the back
                        • Tony 13
                          Tony 13
                          Tony 13
                          Already tweaked a couple of routes. Very useful
                          • Ralph c
                            Ralph c
                            Ralph c
                            Just saw the overlay, and a very big improvement. Like to create my own routes and this helps a lot picking the right roads.
                            Awesome job guys!
                            • Edwin_M
                              Edwin_M
                              Edwin_M
                              #20
                              Bij mij werkt het nog niet echt lekker.
                              Even een route maken in de tuin zorgt alleen maar voor fouten. Ook via de website (op telefoon). Vind het ook best traag
                              Ook een willekeurig ander adres
                              • Edwin_M
                                Edwin_M
                                Edwin_M
                                Update!! Het werkt nu.
                                Zojuist de nieuwe Beta en nu werkt het prima
                                  Fantastisch. Eerst kwam de GPS shop uit Notter met de motorkaart voor de Garmin, speciaal voor motorrijders. En nu komen jullie met iets soortgelijks. Echt vergelijkbaar. Dit maakt alles nog weer mooier!
                                  Fantastic. First came the GPS shop from Notter with the motorcycle map for the Garmin, especially for motorcyclists. And now you come up with something similar. Really similar. This makes everything even more beautiful!
                                  • Edwin_M
                                    Edwin_M
                                    Edwin_M
                                    Te vroeg gejuichd, stap op motor. Klik rondrit. Weer zelfde meldingen. Geforceerd afsluiten en opnieuw, geen verschil
                                    • Edwin_M
                                      Edwin_M
                                      Edwin_M
                                      #24
                                      When I finally got it going.. It came up with route 4 times longer then requested
                                      • Edwin_M Edwin_M
                                        @Edwin_M said in Scenic routing & RouteXpert library improvements:
                                        Daar moeten de dev's zeker nog wat tweaken. Ze hebben deze al in het vizier.
                                        That definitely still needs to be — and is being — tweaked by the devs!
                                        • stuart marritt
                                          stuart marritt
                                          stuart marritt
                                          Trying to do a scenic route from my home to a location all I get is this?
                                          Edwin_M
                                          Edwin_M
                                          Stanisław
                                          Stanisław
                                          iain.gardengmail.com
                                          stuart marritt
                                          stuart marritt
                                          Tony 13
                                          Tony 13
                                          MarcM
                                          MarcM
                                          Ralph c
                                          Ralph c
                                          James Lewington
                                          James Lewington
                                            133
                                            Jörg Neudert
                                            Jörg Neudert
                                            4.7k
                                            4.8k
                                          • Hallo, wéér een nieuwe gebruiker !
                                          • MRA Shop für Merchandise geschlossen ?
