  4. MRA MyRoute app version 4.3.9 - 395 - only shows a very much zoomed in route.
20 Posts 6 Posters 5.0k Views 6 Watching
  • Stanisław
    Stanisław
    Stanisław
    I would also like to see more in the dynamic view mode. Currently, about a third of the screen in horizontal orientation is lost for the sky. I'm afraid the only solution for now is the top view mode where you can select another zoom.
    Staszek
      We fixed some zoom issues in this update.
      What are your visual settings? Perhaps it is a good idea to check them / reconfigure it!
      Inge Bakermans 1 Reply Last reply
      • Stanisław Stanisław
        @Stanisław if that’s the case, check your tilt configuration. Might be a good idea to lower it. Due to a fixed issue your own configuration might not be suitable anymore.
        • Stanisław
          Stanisław
          Stanisław
          Will be tested this weekend 🙂
          Staszek
            Inge Bakermans
            Inge Bakermans
            Inge Bakermans
            @Corjan-Meijerink I know you did tackle some issues, however since the update my zoom is off.
            How should I set the visual settings according to you? For they were fine before the update.
            • Inge Bakermans Inge Bakermans
              @Inge-Bakermans said in MRA MyRoute app version 4.3.9 - 395 - only shows a very much zoomed in route.:
              Go to your app-setting!
              Menubars upper left corner > Account upper right corner > Navigation settings > Map layer > adjust Default zoom correction and/or Tilt correction.
              • Inge Bakermans
                Inge Bakermans
                Inge Bakermans
                Did check and standard zoom correction is 0,0 - tiltcorrection is also 0,0.
                This should not cause the route to be way too much zoomed in, right?
                  @Inge-Bakermans Yep, that should show plenty of map and almost no tilt.
                    Perhaps share a screenshot of what you are seeing and verify if you're not driving in the topdown modus (with fixed zoom).
                    • Stanisław
                      Stanisław
                      Stanisław
                      In my case the tiltcorrection was +8 so it could be wrong setting 🙂
                      Staszek
                      • Inge Bakermans
                        Inge Bakermans
                        Inge Bakermans
                        Will try to do that Corjan.
                        Drove with settings at 0 and still very little zoom.
                        Will take a photo with my phone of the tablet and post it.
                        • Inge Bakermans
                          Inge Bakermans
                          Inge Bakermans
                          How do I check the not driving in fixed zoom btw?
                            #14
                            @Inge-Bakermans Press the compass sign
                            "during navigation mode" and watch the pop up showing the current mode.Screenshot_20250530-131816.png Screenshot_20250530-131829.png Screenshot_20250530-131843.png
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Motorola Edge 40 "offline"
                            Sena SLR 3
                            Sena 50 R
                            • Stanisław
                              Stanisław
                              Stanisław
                              I have done about 1 kkm during the weekend, with the settings tilt correction = 0, it seems ok now - about 300 m ahead visible in the dynamic mode. I use 8'' tablet in horizontal view. Thanks @Corjan-Meijerink !
                              Staszek
                              • Inge Bakermans
                                Inge Bakermans
                                Inge Bakermans
                                Corjan, dit is wat ik zie.
                                • Inge Bakermans
                                  Inge Bakermans
                                  Inge Bakermans
                                  Peter thanks for the photos - will try the pressing of the compass tomorrow when driving.
                                  Have set it for now on dynamic camera on the tablet - landscape.
                                    @Inge-Bakermans that for sure is not dynamic. Indeed tap the compass to switch to it 🙂
                                      @Inge-Bakermans, Your opening post was in English, so I will continue in English. What is it exactly that is not good on your screenshot?
                                      • Inge Bakermans
                                        Inge Bakermans
                                        Inge Bakermans
                                        Am on the road so my apologies for the late reply. have indeed been tapping the compass and have it now way more zommed out - just like I like it. Thanks guys for the help.
                                        Stanisław
                                        Stanisław
                                        Inge Bakermans
                                        Inge Bakermans
                                          92
                                          BMcG
                                          BMcG
                                        • Startpunt wijzigen
                                        • Route exporteren uit beta
                                          Ed van Klink
                                          Ed van Klink
                                        • V6 - Track Navigation
                                          Stevedo 6 0
                                          Stevedo 6 0
                                        • Planning a Mountain Bike Route – Integrating “Off-Road (Straight Lines)” into “Sections”?
                                          Reinhard Punz
                                          Reinhard Punz
