  4. POI import of OV2 file
7 Posts 4 Posters 1.9k Views 1 Watching
  • Tony 13
    Tony 13
    Tony 13
    Hi I got an OV2 file from the SCDB.info website which i tried to upload but got the following dialogue box and could not upload the file
    I did not want to generally share the file as it is a paid for service. However, if someone wants to help by looking at the file happy to share to an individual. thanks
    • Tony 13 Tony 13
      @Tony-13 Hi Tony. Is it what it says, more than 10.000 POI's witch seems to me like a lot?
      • Tony 13
        Tony 13
        Tony 13
        I think it is telling me the problem is either, over 10,000 POIs; OR incorrect POIs; OR no POIs. I think it is the middle option but only a guess
        • Tony 13 Tony 13
          @Tony-13 1.63MB seems a little large for just a list of POIs, I suspect the file contains other data. Have you tried uploading as a route-track?
          • Tony 13
            Tony 13
            Tony 13
            The screen shot is from my first attempt to upload, I also tried a smaller dataset, about 500MB(again does seem rather large for a small data set) and this did not work either
            route/track import does not accept OV2 files
            • Tony 13 Tony 13
              @Tony-13 It's probably like @Nick-Carthew said that there's still other info in the file. Even with 500MB it's way to big for an POI file
              • Tony 13 Tony 13
                @Tony-13, can you re-download the file as a GPX file? I find that much more compatible than anything.
                Tony 13
                Tony 13
                  11.8k
                • Issues on one-way streets when reversing routes
                  35
                • Route line is not easy to follow on map
                • F004 MRA Navigation Error
                • Probleem met eigen Stay
                  Albert van den Elsen
                • I need help with the track navigation settings
                • POI functie 'strict'
