  4. Preference travel
Preference travel
8 Posts 4 Posters 1.7k Views 3 Watching
  • Maurizio Malbertiundefined Offline
    Maurizio Malberti
    Good morning.
    How can I choose to travel on motorways?
    When I upload a.gpx file with highways to travel, the app lets me out and choose very long routes
    Thanks
    Marinus van Deudekomundefined Herman Veldhuizenundefined 2 Replies Last reply
    • Maurizio Malbertiundefined Maurizio Malberti
      Good morning.
      Thanks
      @Maurizio-Malberti maybe wou can share this route's url here and make shure it's set to public so we can help you
        Maurizio Malberti
        https://www.myrouteapp.com/it/social/route/10915820?mode=share
        TomOnTourundefined Marinus van Deudekomundefined 2 Replies Last reply
          TomOnTourundefined Offline
          TomOnTour
          @Maurizio-Malberti Hi Maurizio,
          I just checken your route and if I look at all the shaping points in this route the route is absolute perfect. You have one section of motorways right after beginning and then another one on your way back. In between your shopping points are perfectly used by myRoute APP.
          MyRoute-APP Navigation Next (V5.2.0 - 474) on DMD T665 Navigation phone and on DMD T781
          using iPad Pro (iPadOS 26.5) and Macbook Air (macOS 26.5.1)
          Maurizio Malbertiundefined 1 Reply Last reply
          • TomOnTourundefined TomOnTour
            Maurizio Malberti
            @TomOnTour yes, but when I use the app on my Samsung phone on android auto it always avoids highways. as if when using a common navigator, it was flagged avoid highways
              Good morning.
              Thanks
              Herman Veldhuizenundefined Offline
              @Maurizio-Malberti After you import a gpx file (with waypoints) you get to select route:fastest/shortest and highways yes/no in the Toolkit. When you navigate then the key is whether you navigate as track or not. When starting a navigation you only get to pick route:fastest/shortest and highways:yes/no when you navigate a route as route (and not as a track).
                @Maurizio-Malberti hi Maurizio
                I’ve looked at your route and I’ve noticed a couple of things.
                You use the TomTom map where MRA uses the Here map that allen can realy mess up your route.
                By the hotels in the long route I assume that it’s a 4 days trip. I would break that up in 4 trips. On a totall of more 1500 km there are only 52 waypoints in the route and a lot of them are OFF route. Look at nr 39 it’s on the wrong side of the road resulting in a massive detour.
                So Some tips
                Set the map to Here
                Cut the trip in 4 parts
                Use more shaping points
                Make sure they’re ON the route (zoom in max)
                Have fun
                  So Some tips
                  Set the map to Here
                  Have fun
                  Maurizio Malberti
                  @Marinus-van-Deudekom thank you very much
                  TomOnTourundefined
                  TomOnTour
                  Maurizio Malberti
                    Steve Jarrellundefined
                    Steve Jarrell
                    3.5k
                    205
                  • Move blocks of routepoints
                    Yannick_van_Vugtundefined
                    Yannick_van_Vugt
                    595
                    John S Parryundefined
                    969
                  • Updated beta! 5.2.1 (486)
                    pehaundefined
                    peha
                    467
                  • Offline Track Navigation - Path Errors with Large Distance Between Points
