Minimum tablet requirements for MyRoute App
I currently use a Samsung Galaxy Tab A8 for navigation with MyRoute App.
It has 4g ram and 64g storage.
Is 4g ram enough for MRA. Mine seems quite slow. I have no other apps open while navigating and really have very few apps even loaded on the tablet.
What is the minimum requirements for proper function of MRA.
I may consider changing to an IPad. What would the minimum requirements be for a IPad?
Lee -
Lee@Lee-Parker-1 iPad on motorbike? Not a good idea.
It is not made for outdoor and vibration.
I use an Oukitel RT3 nearly two years and it is still working. -
I use an Oukitel RT3 nearly two years and it is still working.@Jörgen It's actually an interesting subject, how various tablets perform.
I use a Samsung Galaxy Active tablet 3. It works, but performance isn't impressing. I think this mostly depends on the device's CPU.From what I have read, even the newer Active 5 performs equally.
Likely nobody has compared GPS applications on a number of tablets.
@Makro There is a new Oukitel RT3 Pro available (I think below 200€) with a newer Android version, I have no Idea if it is better in performance. Mine is Ok for now and it works fine. I sometimes use two apps in split screen mode and ha´ve no problem.
@Stanisław Hi, swipe your finger slowly upwards from the bottom, stop halfway and tap on the three dots to the right of the app you have just opened and select split screen. Then select the other app to be displayed.
For those using Samsung like me, if anyone should be interested, then split screen can be enabled using finger draw.
https://www.samsung.com/ph/support/mobile-devices/how-to-use-swipe-gestures-with-multi-window/But also in another way: open the list of recent apps, click the app icon and select the split screen option.
This may or may not work on Oukitel
@Stanisław said in Minimum tablet requirements for MyRoute App:
@Jörgen I have just bought RT3 pro, how to get split screen, could you advice me?
Hi, I ask you a favor, could you give me the measurements of the screen and the total size? H, L, in cm? Thank you very much, I want to take it too but I have to see if it fits under the windshield.
@Jörgen said in Minimum tablet requirements for MyRoute App:
@Gaetano-9 https://www.devicespecifications.com/de/model-display/94505b63
Very kind, thank you!
On amazon they give exaggerated measurements.. I think I'll take it immediately. -
On amazon they give exaggerated measurements.. I think I'll take it immediately.@Gaetano-9 I can confirm these values from the link, just measured manually
Ok.. took measurements... The Pad is too big, it doesn't fit under the windshield and in any case for a motorbike I don't find it very proportionate. I opted for a 6.6" Rugged Smartphone, definitely better and highly visible. It's also easier to find brackets. After all, on a motorbike, we go to look at the world and not at a screen.
I will definitely have fewer problems with My Route on my motorbike.
I use an Oukitel RT3 nearly two years and it is still working.@Jörgen what kind of mount are you using ? Thanks !
@Gaetano-9 said in Minimum tablet requirements for MyRoute App:
Nicely said !
@Adrian-Avram a self made DIY.
Lee@Lee-Parker-1 Hi Lee,
I'm driving with a TFT Carpuride W702B.
It has a lot of nits, is waterproof, and can absorb vibrations.
This TFT screen has built-in Apple CarPlay and Android Auto and works perfectly in combination with MRA. -
Here is my final configuration. Instead of the Zumo I put this cell phone, so I eliminated Android Auto that with MyRoute, on a motorcycle, was not the best. Now MRA is perfect.
@Gaetano-9 Which phone do you use now?
