  4. Navigate a route as track -> user error?
8 Posts 3 Posters 1.9k Views 2 Watching
  • Erdna
    Erdna
    Erdna
    wrote on last edited by Erdna
    Cheers from Austria,
    so last weekend I was finally able to test this. The result was: it did not work. So I assume that I am using it wrong.
    The route: https://www.myrouteapp.com/de/social/route/10673164?mode=share
    In Navigator, I enabled the option to use route as track, of course. Unfortunately, on the specific Phone used that day, the track recording is not enabled automatically and I forgot to do that, so I don´t have that available.
    From viapoint 2 on, Navigation obviously wanted to go to the destination as fast as it could and totally ignored the "white line" that was still showing on the screen as the intended way to go. It would have turned me around on several occasions, wanted me to turn where it would absolutely make no sense, and so on.
    Am I missing something? Is this kind of navigation just ignoring any shaping points or what else could I´ve possibly done wrong?
    Thanks in advance for your input. Bigger tours will start as soon as I can get over the Alps w/o freezing my B off and I´d appreciate to know what to do or prevent. 🙂
    Regards,
    André
    Marinus van Deudekom MotoCon 2 Replies Last reply
    • Erdna Erdna
      Regards,
      André
      @Erdna yes André. That’s only an option in MRA
      Erdna 1 Reply Last reply
        Erdna
        Erdna
        Erdna
        @Marinus-van-Deudekom said in Navigate a route as track -> user error?:
        Which does not answer any of my questions.^^
        • Erdna Erdna
          Erdna
          Erdna
          Erdna
          Just to clarify: I thought that after that
          https://youtu.be/71e_-oX4V48?si=n_UnKbb8ypy4B5PI
          I could just easily use track navigation with routes, too. But obviously, I´m missing something. 🙂
          • Erdna Erdna
            @Erdna looping at the shared route, rp2 is a viapoint so mandatory to get there. Might the problem be that you didn’t get to that point therefore the system trying to get you to go to rp2. I was offguard by your word navigator, thinking it was a dédicaces device, you probable meant navigate
              Erdna
              Erdna
              Erdna
              Well that might of course be the case. I´m sure I was because I bought a ticket for highway use. And if I would not have been there, arrival time at target would have massive improved over time - which it did not.
              • Erdna Erdna
                Regards,
                André
                @Erdna said in Navigate a route as track -> user error?:
                No, on the contrary... Usually a sensible way back to the track is provided. What could have gone wrong is that you touched the screen on the routline, specifying your re-entry to the track, indeed by the fastest way. This can simply be corrected by (long)pressing the route line on a point near your location, the track will be re-entered from there.
                  Erdna
                  Erdna
                  Erdna
                  @Con-Hennekens said in Navigate a route as track -> user error?:
                  As far as I rember, I did not touch anything at all. I did not need to, because I know every bend and bump on that roads. But I think we will not get this sorted. I will give Track navigation another try some other time and will update here.
                  Erdna
                  Erdna
                  • synchroniseren tussen de route app en de beta versie
                    Evert 1g
                    Evert 1g
                  • Replies in this section
                    John Matthews 0
                    John Matthews 0
                  • How to change from KM to Miles?
                    John Matthews 0
                    John Matthews 0
                  • Round trip - How to include a waypoint using the app?
                  • Route navigatie simuleren op Windows pc
                    Alderweireld Rudi 0
                    Alderweireld Rudi 0
                    John Matthews 0
                    John Matthews 0
                  • Gegevens Overnachting
