  3. MRA Nav App suitability for off road use
21 Posts 8 Posters 8.9k Views 6 Watching
    @Ton-Machielsen
    Kurviger for off-road? Are you sure?
    Ton Machielsen
    Ton Machielsen
    Ton Machielsen
    @Martin-Wilcke That’s what I do…
    • Ton Machielsen Ton Machielsen
      martin-phogel.de
      martin-phogel.de
      martin-phogel.de
      @Ton-Machielsen
      To recap: Your workflow is to create off-road routes/tracks with Kurviger and navigate them with MRA NN? That sounds super interesting!
      Can you please share one of these as an example? I'm on MRA and Kurviger, both platforms will do.
      Ton Machielsen 1 Reply Last reply
      • LE DIZES Freddy
        LE DIZES Freddy
        LE DIZES Freddy
        Bonjour à tous
        la solution pour faire des itinéraires Route et Off road serait que lorsqu'on utilise la navigation avec MRA la trace apparaisse tout le temps quelque soit le routage fait par l'application . libre a chacun de suivre le routage ou la trace
        • CD130
          Corjan is currently working on it. Hopefully he can share an update on this topic soon.
            Full offroad support will be quite unlikely for our navigation app.
            We are however investigating the support of short offroad sections / "offroad" marked waypoints as shown in the MRA Routeplanner.
            CD130 martin-phogel.de 2 Replies Last reply
              @Corjan-Meijerink That would be a really great improvement and for most users more than enough. Glad you're working on this 👍
                @Ton-Machielsen
                Ton Machielsen
                Ton Machielsen
                Ton Machielsen
                @Martin-Wilcke What do you want me to share? A GPX? I just create my track on Kurviger and export it as GPX into MRA. That’s all.
                  martin-phogel.de
                  martin-phogel.de
                  martin-phogel.de
                  @Ton-Machielsen
                  I'm curious about the "offroad capabilities" of your workflow as I've not managed to get proper results with a similar approach - neither creating a route (without using "beeline") nor navigating a track (except "follow the line visually"). That's why I'm asking.
                  Can you share one of your offroad routes (route-track?) here by providing a link?
                  David Martin Sandilands 1 Reply Last reply
                    martin-phogel.de
                    martin-phogel.de
                    martin-phogel.de
                    That would help a lot! Not only for offroad purposes but also to deal with map data errors (like unknown ferries).
                      @Ton-Machielsen
                      @Martin-Wilcke I don’t have an off road route yet, I hope to be about create on in MRA. Or extract one off the TET website
                      • Ton Machielsen
                        Ton Machielsen
                        Ton Machielsen
                        This is just an example. https://kurv.gr/dHAVv
                          martin-phogel.de
                          martin-phogel.de
                          martin-phogel.de
                          @Ton-Machielsen
                          Thanks for sharing - I'll have a look!
                            martin-phogel.de
                            martin-phogel.de
                            martin-phogel.de
                            @Ton-Machielsen
                            That's an interesting example!
                            I did a quick check, but this route can be created with MRA using OSM (as Routing Engine) but not with HERE. Navigation with MRA NN should work (track navigation) with just a few sections where you must follow the "white line":
                            https://www.myrouteapp.com/en/social/route/10364286?mode=share
                            LE DIZES Freddy
                            LE DIZES Freddy
                            martin-phogel.de
                            martin-phogel.de
                            richard 3v
                            richard 3v
                            Ton Machielsen
                            Ton Machielsen
                              Marcel Versluis
                              Marcel Versluis
                              Parantapa
                              Parantapa
                            • Select friends problem
                            • Android Auto TFT
                            • F019 WebPlaner - MRA V6.0.0 (531) - POI delta detected
