  3. Anyone using a Remotek BT Controller with MRA ?
33 Posts 8 Posters 18.4k Views 6 Watching
    @Kenny-1 I can assure you that you won’t be disappointed.
    Kenny 1
    Kenny 1
    Kenny 1
    @Nick-Carthew May I ask why you choose this particular model from SF as opposed to the 3 button unit or perhaps why you prefer it over the C.I. units ? I will help me decide.
    BMW 800GS, Samsung Tab3 Active
    Carpe Iter rally support arms w Brodit on Ram.
    MRA many years and now with Next
    BV9700 Pro Android Rugged phone and TTR for backup.
    Carpe diem !
    • Kenny 1 Kenny 1
      @Kenny-1 Yes, that's a simple question to answer. The B8J was the only option when I purchased it, the H1 was still on the drawing board 😀
      Kenny 1 1 Reply Last reply
        Kenny 1
        Kenny 1
        Kenny 1
        @Nick-Carthew I have ordered the B8J. I like the xtra function button.
        Carpe diem !
        BMcG 1 Reply Last reply
        • Kenny 1 Kenny 1
          BMcG
          BMcG
          BMcG
          Hi @Kenny-1 sorry looks like I missed the boat on this one
          Other controllers may be superior but there is absolutely nothing wrong with the Remotek,
          it does exactly what it says on the tin.
          It is extremely compact which was the main reason I chose it,
          other controllers fit fine on massive adventure buses but on a sports bike there is just not the space in the cockpit area.
          All the functions on the Remotek work as implemented & one function I find especially useful is its ability to toggle between multiple map/navigations apps.
          I can have MRA running as my main navigation app & in the background also be running Osmand, a quick click & I can switch between apps.
          I find this is especially useful when trying to locate petrol stations as the implementation of this feature still needs quite a bit of work in MRA.
          The only feature I really miss on the Remotek is the ability to Skip points.I don't believe this is an issue with the Remotek itself but rather that the controller profile within MRA omits this functionality. I don't believe it would take much for this to be implemented, I could be wrong but have not been able to get any interest or response to that idea
          Kenny 1 Stanisław 2 Replies Last reply
          • BMcG BMcG
            Kenny 1
            Kenny 1
            Kenny 1
            @Brian-McG Hi Brian, Thanks for jumping in with your comments. It's better to be later than never. I can absolutely appreciate you wanting a smaller controller like the Remotek on a sport bike and comparably the SilverFox is pretty chunky and robust as it was developed with the GS and other adventure bikes as the target group of which I belong. I have a BMW 800GS. My handlebars sometimes take a pretty good trashing in the bush so I always say if it works for you, then it's good for you.
            Carpe diem !
            • BMcG BMcG
              Stanisław
              Stanisław
              Stanisław
              @Brian-McG said in Anyone using a Remotek BT Controller with MRA ?:
              Ii is possible by doubleclick up arrow (as I remember) - menu appears, then select skip next waypoint option and done. Not by one click but possible on Android phone.
              By the way, is there any chance to get more then pan and zoom on Iphone?
              Staszek
              • Kenny 1 Kenny 1
                A few months ago this question was asked by someone using iOS and they were directed to a SilverFox product. There is a significant price difference between the 2 brands and the Remotek sure looks to be up to the task for my purpose with an Android device. Any wisdom on the brand ?
                @Kenny-1
                Hereby s. Picture, it's going very well now, that's all I need, that in the clean iOS entire MRA application.
                Remotek- One comes from off-road use and is very stable. The built-in battery lasts several years 👉
                BT coupling:
                Remotek One and MRA
                In the MRA setting input standard
                iOS Remotek One keyboard.
                It is imperative to set the iOS accessibility / keyboard control to "OFF".
                Then it goes in MRA error-free with the navigation or on the normal maps very well.
                Function:
                Map right, left, top, bottom
                "-/+ Zoom
                Hiermit s. Bild, geht es jetzt sehr sehr gut, mehr brauche ich nicht, das in der sauberen iOS gesamten MRA Anwendung.
                Remotek- One kommt aus dem Geländeeinsatz und ist sehr stabil ausgeführt. Die verbaute Batterie hält mehrere Jahre 👉
                BT Kopplung:
                Remotek One und MRA
                In der MRA Einstellung Eingabe Standart
                iOS Remotek One Tastatur.
                Dabei ist es zwingend notwendig die iOS Bedienungshilfe / Tastatursteuerung auf „AUS“ zu stellen.
                Dann geht es in MRA fehlerfrei bei der Navigation oder auf bei den normalen Karten sehr gut.
                Funktion:
                Karte rechts, links, oben, unten
                „-/+ Zoomen
                Jörgen 1 Reply Last reply
                  @Kenny-1
                  BT coupling:
                  Remotek One and MRA
                  Function:
                  "-/+ Zoom
                  BT Kopplung:
                  Remotek One und MRA
                  Funktion:
                  „-/+ Zoomen
                  @Hubert-Thoring is there nothing more with the Remotek, like "skip waypoint" "open menu"? Barbuttons and Motorbuttons can.
                  • Jörgen Jörgen
                    @Jörgen double click the right button will skip a waypoint 🙂
                    https://support.myrouteapp.com/en/support/solutions/articles/12000100670-bluetooth-controllers
                    It does contain a small mistake I see. The skip waypoint is missing (it says start navigation but that is true only for map home screen)
                    • Jörgen
                      @Corjan-Meijerink None of the linked pages from the controller overview works for me.
                      e.g. https://myrouteapp.freshdesk.com/nl/support/solutions/articles/12000100670
                      • Jörgen Jörgen
                        Kenny 1
                        Kenny 1
                        Kenny 1
                        wrote on last edited by Kenny 1
                        #19
                        So this is what it looks like when your post is hijacked and morphed into a sidebar discussion that is completely off the original topic. I was going so well for the first 10 or so responses. 🙄
                        Carpe diem !
                        • Kenny 1 Kenny 1
                          @Kenny-1 We're still discussing the Remotek and the possibilities with it 😉 Seems on topic to be fair.
                            Kenny 1
                            Kenny 1
                            Kenny 1
                            #21
                            @Corjan-Meijerink I'm just a guest here but it seems if you want to continue deeper technical aspects of a product rather than user experience than a new topic should/ could be started or an older one picked back up imho.
                            Carpe diem !
                            • Jörgen
                              @Kenny-1 I am not sure what you mean? We talk about Remotek and I wanted to know what is supported by this device.
                              Isn't that also your question?
                              • Kenny 1
                                Kenny 1
                                Kenny 1
                                @Jörgen Perhaps it is a problem with the language but it seems that there are a handful of people involved in some deeper technical issues regarding the programming and specific button functions on the Remotek unit and NOT the general user experience. Basically, referring to my initial post I was only trying to get the general user experience for this brand of controller. I'm not interested in "Detailed" technical issues and the resolution of them. It is enough for me to know there are certain issues , or the quality / price relationship is good or not good, or it is robust or not, or the buttons are easy to operate etc. If you have ongoing programming issues you'd like to explore and discuss, than that is ok and can be a good thing, but open a new thread for that under a technical topic please.
                                Carpe diem !
                                • Stanisław
                                  Stanisław
                                  Stanisław
                                  In my opinion it is very good product, easy to install (no wire), so easy to move between motorcycles. The buttons work very reliably and it makes a good impression.
                                  Staszek
                                  • Stanisław Stanisław
                                    Kenny 1
                                    Kenny 1
                                    Kenny 1
                                    @Stanisław Perfect ! Thank you.
                                    Carpe diem !
                                      My biggest issue with the Remotek from a user experience perspective is that they put alternative functions in a double click action.
                                      With how the device is mounted and the robustness of the buttons (in general a good thing, nice hard & firm click) it is almost impossible to double click while driving 😉
                                      All other controllers I know of use a long click specifically for this issue.
                                      Stanisław Kenny 1 2 Replies Last reply
                                        Stanisław
                                        Stanisław
                                        Stanisław
                                        @Corjan-Meijerink The best option would be to have both double-click and long press to be used for different actions 🙂 It is not a big deal for me to double-click and switching between selected apps is very good idea - unfortunately it is covering next waypoint omitting, because it is right double-click.
                                        Staszek
                                          Kenny 1
                                          Kenny 1
                                          Kenny 1
                                          @Corjan-Meijerink Thank you Corjan. On further research and recommendation I have purchased a SilverFox. I only have 1 bike and I need heavy duty and ease of operation.
                                          Carpe diem !
                                          Stanisław
                                          Stanisław
                                          BMcG
                                          BMcG
                                          Kenny 1
                                          Kenny 1
                                          • Testroute segmenten
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            105
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Tegel Werner
                                            Tegel Werner
                                          • Units of Measurement
                                            David Weedon
                                            David Weedon
                                            Andy Smith 5
                                            Andy Smith 5
