  4. When uploading routes….
3 Posts 3 Posters 832 Views 2 Watching
  • Richard 18 Offline
    Richard 18 Offline
    Richard 18
    wrote on last edited by Richard 18
    The default tab is to upload a route.
    More often than not, I prefer to upload a track, particularly when it has come from a third party, not least as I am unlikely to ride the route exactly as the third party did.
    Is there a possibility to give the user the upload option default to ‘track’?
    Thank you.
    Brian McG 1 Reply Last reply
    • Richard 18 Richard 18
      Thank you.
      Brian McG Offline
      Brian McG Offline
      Hi @Richard-18 I also think the upload dialog window can be a bit of a pain to use.
      Often all I recieve is a gpx file with no clue if it is a route or a track.
      My issue is that the only way I can find out with MRA which it is, route or track, is to go the though the file picker process & then be told the gpx is not a route.
      I then have to close the Upload window & repeat the whole process again selecting Route-Track.
      If it was simply possible within the Upload window to swap/choose between Route or Track after the file picker process it would be a bit easier to use
      It is a small issue but one I have repeated hundreds (thousands) of times hence the pain 🤕
      • Brian McG Brian McG
        @Brian-McG, I agree. Usually I import the route as well as the track so that are 2 uploads where 1 could suffice. I do this so I can confirm the route to the track, and make changes where needed.
        1 - upload file
        2 - windows shows contents of file (route, tracks, POI, can all be multiple, technically)
        3 - select the items to process into MRA (no matter the type)
        4 - press "Process" to get them into MRA
        Richard 18
        Richard 18
        • Carpuride scherm vast
          De Ploey Georges
          De Ploey Georges
          1.3k
          14.6k
        • How can I change the verbal navigation directions from male to female?
          369
        • Apple Carplay - navigatie instructies zichtbaar, maar kaart niet??
        • Camperroutes
          De Ploey Georges
          De Ploey Georges
        • Wegwerkzaamheden / Road works
        • Not a great route choice
