  4. When uploading routes….
3 Posts 3 Posters 1.0k Views 2 Watching
  • Richard 18
    Richard 18
    Richard 18
    wrote on last edited by Richard 18
    The default tab is to upload a route.
    More often than not, I prefer to upload a track, particularly when it has come from a third party, not least as I am unlikely to ride the route exactly as the third party did.
    Is there a possibility to give the user the upload option default to ‘track’?
    Thank you.
    BMcG 1 Reply Last reply
    • Richard 18 Richard 18
      Thank you.
      BMcG
      BMcG
      BMcG
      Hi @Richard-18 I also think the upload dialog window can be a bit of a pain to use.
      Often all I recieve is a gpx file with no clue if it is a route or a track.
      My issue is that the only way I can find out with MRA which it is, route or track, is to go the though the file picker process & then be told the gpx is not a route.
      I then have to close the Upload window & repeat the whole process again selecting Route-Track.
      If it was simply possible within the Upload window to swap/choose between Route or Track after the file picker process it would be a bit easier to use
      It is a small issue but one I have repeated hundreds (thousands) of times hence the pain 🤕
      • BMcG BMcG
        @Brian-McG, I agree. Usually I import the route as well as the track so that are 2 uploads where 1 could suffice. I do this so I can confirm the route to the track, and make changes where needed.
        1 - upload file
        2 - windows shows contents of file (route, tracks, POI, can all be multiple, technically)
        3 - select the items to process into MRA (no matter the type)
        4 - press "Process" to get them into MRA
        BMcG
        BMcG
        Richard 18
        Richard 18
        • Testroute segmenten
          Alderweireld Rudi 0
          Alderweireld Rudi 0
          95
          Hanza 0
          Hanza 0
          Jack 13
          Jack 13
        • Units of Measurement
        • Eindtijd zichtbaar.
          Ruurt Visser
          Ruurt Visser
        • Photo information for the travel diary
        • Map Layers
          Martin White
          Martin White
